Fan2 for light
I have an effector light connected to fan2 on radds When I press light on radds display it goes on for a second then goes off. When I start the printer it also goes on for a second then goes off. Why doesn't stay on?
config:
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define BOARD_FAN_SPEED 255
#define FAN_THERMO_PIN -1
#define FAN_THERMO_THERMISTOR_TYPE 14
and
#define SD_RUN_ON_STOP ""
#define SD_STOP_HEATER_AND_MOTORS_ON_STOP 0
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_FAN2_CONTROL 1
#define FEATURE_CONTROLLER 7
#define ADC_KEYPAD_PIN -1
pin:
#define SDSUPPORT 1
#define SDPOWER -1
// 4,10,52 if using HW SPI.
#define SDSS 4
#define ORIG_SDCARDDETECT 14
#define LED_PIN -1
#define ORIG_FAN_PIN 9
#define ORIG_FAN2_PIN 8
#define ORIG_PS_ON_PIN 40
#define KILL_PIN -1
#define SUICIDE_PIN -1 //PIN that has to be turned on right after start, to keep power flowing.
// 20 or 70
#define SDA_PIN 20
// 21 or 71
#define SCL_PIN
CASE_LIGHTS_PIN whcih I do not see in your config part.
mean enable second fan and that also uses FAN2_PIN and will disable a light enabled with M355.In that case
M106 P1 S255 should enable the light.
should be set so it does not use same pin. Also check if you have no cooler pins set to fan 2.
