Repetier Server on windows 10 stop automatic
I have installed Repetier Server on a windows 10 notebook. If I start the server so its working for 20 seconds afterwards the server cannot be connected anymore. The service is stoped . If I restart the service its working for 20 seconds and afterwarts the same problem. I have tested to disactivate the firewall and also the antivirus but nothing has resolved the problem. Has you some ideas what I can do to make the server running?
Thank you
withewolf
Thank you
withewolf
C:\ProgramData\Repetier-Server\logs\server.log
if it contains any hints and show where it stops. Maybe then it gets clear what might prevent startup.
thank you for the answer but nothing that looks strange:
The log from today:
2017-10-07 17:37:04: Start logging...
2017-10-07 17:37:05: Webdirectory: C:\Program Files (x86)\Repetier-Server\www\
2017-10-07 17:37:05: Storage directory: C:\ProgramData\Repetier-Server\
2017-10-07 17:37:05: Configuration file: C:\Program Files (x86)\Repetier-Server\bin\RepetierServer.xml
2017-10-07 17:37:05: Directory for temporary files: C:\Windows\Temp\
2017-10-07 17:37:05: Reading firmware data ...
2017-10-07 17:37:05: Starting Network ...
2017-10-07 17:37:05: Active features:0
2017-10-07 17:37:05: Reading printer configurations ...
2017-10-07 17:37:05: Starting printer threads ...
2017-10-07 17:37:05: Starting work dispatcher subsystem ...
2017-10-07 17:37:05: Starting user database ...
2017-10-07 17:37:05: Initalizing LUA ...
2017-10-07 17:37:05: Register LUA cloud services
2017-10-07 17:37:05: add Repetier-Renderer
2017-10-07 17:37:05: LUA initalization finished.
2017-10-07 17:37:05: Starting web server ...
2017-10-07 17:37:05: Work dispatcher thread started.
2017-10-07 17:37:05: Prevent sleep thread started.
2017-10-07 17:37:05: Webserver started.
Thank You
withewolf
So if that is all you get it crashes. I see you have no printers configured yet, so sinc eit normally works on W10 I would after it is shut down delete
So it has to recreate everything.
One other problem is that port 3344 might be already in use by a different software preventing webserver to work, but would hope to see a message about that. Maybe your windows event log has some more informations.
You can use a different port. In C:\ProgramData\Repetier-Server\database
create a RepetierServer.xml file with this content
where you select a different port and restart. Then check if it runs longer.
