Repetier server 502 Bad Gateway error
I'm running Repetier server image on Raspberry Pi (version 0.85.2). There were some issues with the web interface, so I restarted the pi. Then after the reboot it couldn't find the printer and said there is some unknown printer connected. I tried configuring this unknown printer but it froze on Automatic settings import from firmware. I restarted the Pi again and after that it no longer works and shows 502 bad gateway error.
I tried starting in manually from the console and here is what I saw in output:
I've checked the file size for OLP.xml and it was zero. So, it looks like if printer config file becomes empty (or damaged?) the server crashes and no longer shows web interface. Deleting the empty file and restarting server helped (it stopped crashing and I could add and configure the printer again).
Reading printer config /var/lib/Repetier-Server/configs/OLP.xml error: No element found in line 1 column 0 Starting printjob manager thread for unknown Starting printer threads ... Starting work dispatcher subsystem ... Starting user database ... Starting printer thread for unknown Importing wifi connections from /boot/repetier-network.xml Importing wifi connections from /var/lib/Repetier-Server/database/repetier-network.xml Importing wifi connections from /var/lib/Repetier-Server/database/repetier-network-stored.xml Initalizing LUA ... Starting wifi watcher ... Register LUA cloud services add Repetier-Renderer LUA initalization finished. Starting web server ... Work dispatcher thread started. Webserver started. AborterReading printer configurations ...
https://forum.repetier.com/discussion/4053/new-image-for-sd-has-a-bug#latest
for mor einfos and how to help us finding the source of th eproblem.
But it is important to reboot to be sure it reloaded. Deleting shoudl also be done when server is not running to prevent write backs.
