Z leveling with probe mysteries ?????
The worst part is that, at some point, it was working, more or less.
OK, I was having problems achieving properly G32. I thought it was my probe, working on 5 volts instead of 12. So I changed it, rewired so that the new one is properly working on 12 volts, with the signal at 4.5V. I tested on an Arduino before plugin it on the printer, and everything works as expected. BUT NOTHING CHANGED, so the probe is not the problem!
What happens is that, when I run a G32 command, it starts Ok with the first couple of rows, then it start pushing/crashing into the bed. I must add that before I level X axis and bed with a digital level box, and I have less than 1/10 of a degree of error.
here is the last attempts reasults:
I am certainly doing something wrong in my settings, but I am unable to pinpoint what, exactly. Here is the relevant part of my configuration.h
Hoping you can help me here, as for now, I am stuck with this and unable to use bed leveling.
Thanks!
12:34:02.634: Info:Autolevel matrix resetAs you can see, the measures looks normal, then suddenly it press onto the bed to find more than 6 mm difference, which is just impossible! Note that I made sure to remove/disable any pre-existing correction.
12:34:23.811: Info:Resetting Z correction
12:35:15.719: Z correction disabled (2)
12:35:20.150: Z-probe:9.04 X:-4.99 Y:10.00
12:35:26.253: Z-probe:9.08 X:-4.99 Y:46.24
12:35:32.386: Z-probe:9.15 X:-4.99 Y:82.49
12:35:38.520: Z-probe:9.11 X:-4.99 Y:118.74
12:35:44.669: Z-probe:9.15 X:-4.99 Y:155.00
12:35:51.575: Z-probe:9.51 X:33.74 Y:10.00
12:35:57.914: Z-probe:9.55 X:33.74 Y:46.24
12:36:04.284: Z-probe:9.62 X:33.74 Y:82.49
12:36:10.655: Z-probe:9.61 X:33.74 Y:118.74
12:36:17.041: Z-probe:9.64 X:33.74 Y:155.00
12:36:24.120: Z-probe:9.65 X:72.50 Y:10.00
12:36:32.004: Z-probe:15.67 X:72.50 Y:46.24
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 0
#define FEATURE_Z_PROBE 1
#define Z_PROBE_PULLUP 1
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 30
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 4
#define Z_PROBE_XY_SPEED 250
#define Z_PROBE_SWITCHING_DISTANCE 3.52
#define Z_PROBE_REPETITIONS 5
#define Z_PROBE_HEIGHT 1.20
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 1
#define Z_PROBE_Y1 1
#define Z_PROBE_X2 160
#define Z_PROBE_Y2 1
#define Z_PROBE_X3 1
#define Z_PROBE_Y3 160
#define BED_LEVELING_METHOD 1
#define BED_MOTOR_1_X 1
#define BED_MOTOR_1_Y 1
#define BED_MOTOR_2_X 170
#define BED_MOTOR_2_Y 1
#define BED_MOTOR_3_X 170
#define BED_MOTOR_3_Y 170
#define FEATURE_AXISCOMP 1
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
Thanks!
How did it print before using bed levelling?(just curious).
It was printing pretty well before print leveling, I just got tired to have to adjust the bed so often to get it level.
My printer is an Anet A8, I have a 0.8 mm PEI on top of the Aluminium bed, which is NOT on when I attempt to setup bed leveling. The Probe is Omron TL-Q5MC1-Z.
You say "or some other thing". What other things should I be looking for?
What I see looks like different results, that is the led light sometimes goes on at what I believe is a normal distance, like +-2mm above the bed, but sometimes it goes on AFTER touching the bed, and sometimes not at all!
Could it be some wrong settings on my side, or something faulty on the electronic side?
Since it is a inductive probe you should have bed disabled when measuring. I think in 1.0 I even disable it actively when probing, but not sure if that was in public version or for a vendor. Also it might measure differently depending on the area of metal below. If you can make it less sensitive so it needs to go closer to bed. That would normally help with accuracy. If they are hyper sensible there are just too much electric fields that can influence it.
I have not seen a way to make it less sensitive. If this does not work, would there be probes you would recommend over the one I have?
That's it! So, yes, it IS hardware related, it's just that, between the probe and the controler, communication might be a bit slow...
here is my last, successful, attempt at G32:
I don't know if a maximum difference of 0.6 mm is bad, but it seems a lot more consistent with my bed than 6 mm, that's for sure!
0.6mm is much in the sense of could not print good without correction. It will also keep the z axis moving a lot. So also it now gets corrected automatically it would improve if you correct the bed a bit manually. The less you have to correct the better.
BTW, did I understand correctly if I believe the correction is applied to the first 5 or 6 layers, then diminish to the point there is no correction at all after a few more layers?
What you mean is distortion correction G33 which is only working correctly in 1.0 which you can not use due to size limits.
I still have a little problem I can't figure out: When doing Home Z (G28 Z), I see the nozzle and probe going down slowly, the probe sensing the height and stopping the motion down, so it looks OK. But then the nozzle is moving up a little bit, going down again, then pressing on the Bed, going up a bit more, going down faster into the bed!
So it looks like the first movement down is not really taken into account, as I have to set a Z offset of 1.8 mm to avoid scratching the bed surface when printing!
Is there values to adjust in EEPROM to avoid this?
Thanks!
I will try adding some bed coating.
