Delta G32 S2
I have Delta printer which succesfully run MArlin, but I decided to switch to Repetier.
Almost everythin runs as expectet except Calibration
I"v set Endstop Offsets, then I"v run G32 S2 and probing starts but eventually
goes beyond my printer Radius
How end where to set probing points or matrix
Regards
Mario
  • You set them in eeprom. Depening on measurement method the 3 points only are used or they build a parallelogram. P1 is one edge and p1-p2 and p1-p3 biod the 2 axis.
  • so these are my Values:
    < 20:02:38: EPR:3 816 20.000 Z-probe X1 [mm]
    < 20:02:38: EPR:3 820 20.000 Z-probe Y1 [mm]
    < 20:02:38: EPR:3 824 160.000 Z-probe X2 [mm]
    < 20:02:38: EPR:3 828 20.000 Z-probe Y2 [mm]
    < 20:02:38: EPR:3 832 100.000 Z-probe X3 [mm]
    < 20:02:38: EPR:3 836 160.000 Z-probe Y3 [mm]
    so for delta I must change some to negative Values
    as Center of Delta Bed is 0,0
    So something like this:
    < 20:02:38: EPR:3 816 -80.000 Z-probe X1 [mm]
    < 20:02:38: EPR:3 820 -80.000 Z-probe Y1 [mm]
    < 20:02:38: EPR:3 824 -80.000 Z-probe X2 [mm]
    < 20:02:38: EPR:3 828 80.000 Z-probe Y2 [mm]
    < 20:02:38: EPR:3 832 80.000 Z-probe X3 [mm]
    < 20:02:38: EPR:3 836 -80.000 Z-probe Y3 [mm]
    Is this correct ?
  • Yes if the edges of the square can be reached with active probe this would be fine.
  • Hi again,
    I"v made the changes but now G32 S2 sonly starts homing and then stops
    G30 test shows that probe is working
    Bellow is my Configuration file
    #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
       generator: http://www.repetier.com/firmware/v092/
       as you expect.
    #define NUM_EXTRUDER 1
    #define MOTHERBOARD 33
    #include "pins.h"
        #undef FAN_BOARD_PIN
        #define FAN_BOARD_PIN -1
        #define BOARD_FAN_SPEED 255
        #define FAN_THERMO_PIN -1
        #undef X_MIN_PIN
        #define X_MIN_PIN ORIG_X_MAX_PIN
    #undef Y_MIN_PIN
    #define Y_MIN_PIN ORIG_Y_MAX_PIN
    #undef Z_MIN_PIN
    #define Z_MIN_PIN ORIG_Z_MAX_PIN
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 3
    #define ZAXIS_STEPS_PER_MM 100
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 198
    #define EXT0_INVERSE 1
    #define EXT0_ENABLE_ON 0
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_HEAT_MANAGER 1
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_PGAIN_OR_DEAD_TIME 36.53
    #define EXT0_PID_I 6.73
    #define EXT0_PID_D 49.60
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 1
    #define HAVE_HEATED_BED 1
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_SENSOR_PIN 14
    #define HEATED_BED_HEATER_PIN 8
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   142.65
    #define HEATED_BED_PID_IGAIN   18.02
    #define HEATED_BED_PID_DGAIN 282.37
    #define MIN_EXTRUDER_TEMP 150
    #define MAXTEMP 285
    // ##                             Laser configuration                                      ##
    automatically disabled.
    #define SUPPORT_LASER 0
    #define LASER_PIN -1
    #define LASER_ON_HIGH 1
    // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    //#define ENDSTOP_PULLUP_X_MIN true
    //#define ENDSTOP_X_MIN_INVERTING false
    //#define MIN_HARDWARE_ENDSTOP_X false
    //#define ENDSTOP_PULLUP_Y_MIN true
    //#define ENDSTOP_Y_MIN_INVERTING false
    //#define MIN_HARDWARE_ENDSTOP_Y false
    //#define ENDSTOP_PULLUP_Z_MIN true
    //#define ENDSTOP_Z_MIN_INVERTING false
    //#define MIN_HARDWARE_ENDSTOP_Z false
    #define min_software_endstop_z true
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_ON_HOME 1
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_X_DIR 0
    #define INVERT_Y_DIR 0
    #define INVERT_Z_DIR 0
    #define X_HOME_DIR 1
    #define Y_HOME_DIR 1
    #define Z_HOME_DIR 1
    #define X_MAX_LENGTH 279.7
    #define Y_MAX_LENGTH 279.7
    #define Z_MAX_LENGTH 279.7
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 60
    #define DISTORTION_YMAX 60
    // ##                           Movement settings                                          ##
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_DIAGONAL_ROD 327.7 // mm
    #define DELTA_ALPHA_A 210
    #define DELTA_ALPHA_B 330
    #define DELTA_ALPHA_C 90
    #define DELTA_MAX_RADIUS 125
    #define ROD_RADIUS 162.5
    #define PRINTER_RADIUS 162.5
    #define DELTA_HOME_ON_POWER 0
    #define STEP_COUNTER
    #define DELTA_Y_ENDSTOP_OFFSET_STEPS 256
    #define DELTA_Z_ENDSTOP_OFFSET_STEPS 89
    //#define SOFTWARE_LEVELING
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 250
    #define MAX_FEEDRATE_Y 250
    #define MAX_FEEDRATE_Z 250
    #define HOMING_FEEDRATE_X 80
    #define HOMING_FEEDRATE_Y 80
    #define HOMING_FEEDRATE_Z 80
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 1650
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 1650
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 1650
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 2000
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 2000
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 2000
    #define MAX_JERK 20
    #define MAX_ZJERK 20
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define X2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Y2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Z2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Z3_STEP_PIN   ORIG_E2_STEP_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 250000
    #define ENABLE_POWER_ON_STARTUP 0
    #define POWER_INVERTING 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 9
    #undef PS_ON_PIN
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
    #define FEATURE_SERVO 0
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define UI_SERVO_CONTROL 0
            #define FEATURE_WATCHDOG 0
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 1
    #define FEATURE_Z_PROBE 1
    #define Z_PROBE_PULLUP 1
    #define Z_PROBE_ON_HIGH 1
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_Y_OFFSET 0
    #define Z_PROBE_SPEED 2
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_REPETITIONS 1
    #define Z_PROBE_HEIGHT 10
    #define FEATURE_AUTOLEVEL 1
    #define Z_PROBE_X1 -80
    #define Z_PROBE_Y1 -80
    #define Z_PROBE_X2 -80
    #define Z_PROBE_Y2 80
    #define Z_PROBE_X3 80
    #define Z_PROBE_Y3 -80
    #define BED_LEVELING_METHOD 1
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 1
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 1
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #endif
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 11
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 0
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 0
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 0
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 0
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 0
    #define LANGUAGE_TR_ACTIVE 0
    #define UI_PRINTER_NAME "Delta Delta"
    #define UI_PRINTER_COMPANY "Antonio"
    #define UI_ANIMATION 0
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 2
    #define UI_REVERSE_ENCODER 1
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 1
    #define CASE_LIGHTS_PIN -1
    #define UI_SET_PRESET_EXTRUDER_TEMP_PLA   190
    #define UI_SET_PRESET_EXTRUDER_TEMP_ABS   240
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define UI_SET_MAX_EXTRUDER_TEMP   290
    #define NUM_MOTOR_DRIVERS 0
    #endif
  • What does the log show as reason for the stop.
    Also config is not relevant if z probe is working. Important is what coordinates are stored in eeprom i guess. And i think it is a problem with one of the positions stored that causes the stop.
  • effector move to first point and stops above cca 20 mm above bed
    error message
    < 06:54:56: X:0.00 Y:0.00 Z:279.700 E:0.0000
    < 06:55:00: Error:z-probe triggered before starting probing.
    < 06:55:00: Error:Probing had returned errors - autoleveling canceled.
    < 06:55:00: X:-60.00 Y:-50.00 Z:20.290 E:0.0000
    < 06:55:00: fatal:G32 leveling failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
  • It was the Z probe, strangley the probe is defect
    thanks
  • Is it defect or did you not go up enough so that it untriggers? Function awaits that it is untriggered so we can go down until it triggers to have a measurement. Starting to low causes the same error.
  • no the switch on the probe is Mechanically defect, yesterday it was OK
    but Today it is not.
