"Connection Lost" when I try to upload files
Everything seems to be running properly with regards to controlling my printer through the server. I can move all axis, heat the bed and extruders, control the fan speed, and extrude. I have a Solidoodle Apprentice, running the server on my Raspberry Pi B+, and running server version 0.51.1.
When I try to upload a file to the server, it gives me a "connection lost" error. I have tried it wired and wirelessly, and have tried ascii, binary, all combinations of files that I can think of to create the g-code file. Is there a secret to uploading the file that I am not seeing? I am anxious to see if I can get this server to print. Thanks.
Joe
I am creating my 3d files in Rhinoceros. They have printed on the printer via USB. I have been creating the g-code file with Repetier Host that I downloaded from Solidoodle and is set up for my printer. I just tried to create the gcode file directly through Slic3r and I still received the same error.
For these files, I have been using my wifi connection, but I had tried a wired connection in the past.
