print stopping with error message "mintemp triggered"
everytime I start a print, after a few hours (almost always after the same amount of time) the print is halted because it says the extruder has triggered the mintemp. The other weird thing happening, is that sometimes, the extruder temperature drops, and shows in the log two lone "cold extrusion prevented" both registered at the exact same time, and then its back to normal again. But right before i get the message that the mintemp has been triggered by the extruder, there are a series of "cold extrusion prevented" until it shuts down.
I've changed the thermistor and it still happens, so would anyone have any further insight on this? is my heater cartridge bad?
That means there is no reading at all, not even room temperature. So that would not depend on getting no power. It is more the other way around. Because of this error firmware disables heaters and then it gets colder and doe snot heat any more. For this a short interruption of the cable is enough. Have heard about printers where the pressure on the sensor was big enough to make them fail after a while when being hot. Might as well be your problem. So in any case if you get the mintemp triggered regularly switch the thermistor and try again.
