The extruder is not controlled and the function "Enable arc support (G2 / G3)" does not work. v092.9
Hello.
I was looking for firmware for the DUE controller.
I decided to try Firmware Repetier-Firmware version 0.92.9
Shield production of my friend.
I have one moment on the control board two ports for extruders, the first one does not work, the extruder is connected to the second port, one extruder and the port for the Extruder .
And so the first question on the extruder:
I'm using Repetier-Host 2.0.5 and Simplify3D 4.0.0, tried and Cura_15.04.6 and higher - the problem is the same.
The printer is connected to the X / Y / Z axis and the extruder does not receive any signals.
In the program Repetier-Host 1.6.1 everything works.
I tried the tool number in the settings of Simplify3D, it did not give a positive result.
Can I do something else in Repetier-Host 2.0.5 and Simplify3D?
And he just does not know where to send signals.
And now the second question on the function "Enable arc support (G2 / G3)":
Despite the fact that the function is connected during the formation of the firmware in the configurator, when printing starts, the circles are printed with straight lines, respectively, a strong vibration occurs and this affects the quality of the external walls - it is horrible.
This happens in any print control program Repetier -Host 1.6.1 and in Repetier-Host 2.0.5, and Simplify3D 4.0.0, tried and Cura_15.04.6 and higher.
But in Simplify3D 4.0.0 there is a function "Apply toolhead offsets to G-code coordinates" - this function just turns on G2 / G3, when enabled, it moves smoothly around the circle.
I tried version 91.rv8 - at compilation produces an error:
"Exit status 1
'PS_ON_PIN' was not declared in this scope "
Denis.
P.S. Sorry for my bad english.
"Exit status 1
Denis.
Your extruder problem is either wrong configuration or hardware problem. Hosts just send commands to heat extruders or extrude (which inly works when hot or it might just be ignored).
Why in the younger version works and in the senior does not exist?
And stable version 0.91 rv8 produces an error when compiling:
Arduino: 1.8.3 (Windows 7), Плата:"Arduino Due (Native USB Port)"
In file included from sketch\Configuration.h:42:0,
from sketch\Repetier.h:117,
from sketch\Commands.cpp:22:
sketch\pins.h:303:0: warning: "E1_PINS" redefined [enabled by default]
#define E1_PINS
In file included from sketch\pins.h:285:0,
from sketch\Configuration.h:42,
sketch\userpins.h:124:0: note: this is the location of the previous definition
#define E1_PINS ORIG_E1_STEP_PIN,ORIG_E1_DIR_PIN,ORIG_E1_ENABLE_PIN,
sketch\pins.h:307:0: warning: "E2_PINS" redefined [enabled by default]
#define E2_PINS
sketch\userpins.h:125:0: note: this is the location of the previous definition
#define E2_PINS ORIG_E2_STEP_PIN,ORIG_E2_DIR_PIN,ORIG_E2_ENABLE_PIN,
In file included from sketch\Repetier.h:264:0,
sketch\HAL.h:42:0: warning: "F_CPU" redefined [enabled by default]
#define F_CPU 21000000 // should be factor of F_CPU_TRUE
<command-line>:0:0: note: this is the location of the previous definition
sketch\HAL.h:61:0: warning: "PSTR" redefined [enabled by default]
#define PSTR(s) s
In file included from C:\Users\Cyber\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\cores\arduino/WString.h:29:0,
from C:\Users\Cyber\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\cores\arduino/Print.h:26,
from sketch\HAL.h:38,
from sketch\Repetier.h:264,
C:\Users\Cyber\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\cores\arduino/avr/pgmspace.h:34:0: note: this is the location of the previous definition
#define PSTR(str) (str)
sketch\HAL.h:62:0: warning: "pgm_read_byte_near" redefined [enabled by default]
#define pgm_read_byte_near(x) (*(int8_t*)x)
C:\Users\Cyber\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\cores\arduino/avr/pgmspace.h:108:0: note: this is the location of the previous definition
#define pgm_read_byte_near(addr) pgm_read_byte(addr)
sketch\HAL.h:63:0: warning: "pgm_read_byte" redefined [enabled by default]
#define pgm_read_byte(x) (*(int8_t*)x)
C:\Users\Cyber\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\cores\arduino/avr/pgmspace.h:102:0: note: this is the location of the previous definition
#define pgm_read_byte(addr) (*(const unsigned char *)(addr))
sketch\HAL.h:65:0: warning: "pgm_read_word" redefined [enabled by default]
#define pgm_read_word(addr) (*(const unsigned int *)(addr))
C:\Users\Cyber\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\cores\arduino/avr/pgmspace.h:103:0: note: this is the location of the previous definition
#define pgm_read_word(addr) (*(const unsigned short *)(addr))
sketch\HAL.h:152:0: warning: "LOW" redefined [enabled by default]
#define LOW 0
In file included from C:\Users\Cyber\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\cores\arduino/Arduino.h:44:0,
from sketch\HAL.h:137,
C:\Users\Cyber\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\cores\arduino/wiring_constants.h:27:0: note: this is the location of the previous definition
#define LOW 0x0
sketch\HAL.h:153:0: warning: "HIGH" redefined [enabled by default]
#define HIGH 1
C:\Users\Cyber\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\cores\arduino/wiring_constants.h:26:0: note: this is the location of the previous definition
#define HIGH 0x1
In file included from sketch\ui.h:192:0,
from sketch\Repetier.h:271,
sketch\uilang.h:1096:34: warning: invalid suffix on literal; C++11 requires a space between literal and identifier [-Wliteral-suffix]
#define UI_TEXT_EXTR0_SELECT "%X0 V"STR_auml"lj Extr. 1"
sketch\uilang.h:1097:34: warning: invalid suffix on literal; C++11 requires a space between literal and identifier [-Wliteral-suffix]
#define UI_TEXT_EXTR1_SELECT "%X1 V"STR_auml"lj Extr. 2"
sketch\uilang.h:1098:34: warning: invalid suffix on literal; C++11 requires a space between literal and identifier [-Wliteral-suffix]
#define UI_TEXT_EXTR3_SELECT "%X2 V"STR_auml"lj Extr. 3"
In file included from sketch\ui.h:410:0,
sketch\uiconfig.h:68:0: warning: "UI_DISPLAY_CHARSET" redefined [enabled by default]
#define UI_DISPLAY_CHARSET 1
sketch\userpins.h:93:0: note: this is the location of the previous definition
#define UI_DISPLAY_CHARSET 0
sketch\uiconfig.h:146:0: warning: "UI_ANIMATION" redefined [enabled by default]
#define UI_ANIMATION false // Animations are too slow
In file included from sketch\Repetier.h:117:0,
sketch\Configuration.h:313:0: note: this is the location of the previous definition
#define UI_ANIMATION 0
sketch\uiconfig.h:150:0: warning: "UI_COLS" redefined [enabled by default]
#define UI_COLS (UI_LCD_WIDTH/UI_FONT_WIDTH)
sketch\userpins.h:94:0: note: this is the location of the previous definition
#define UI_COLS 20
sketch\uiconfig.h:151:0: warning: "UI_ROWS" redefined [enabled by default]
#define UI_ROWS (UI_LCD_HEIGHT/UI_FONT_HEIGHT)
sketch\userpins.h:95:0: note: this is the location of the previous definition
#define UI_ROWS 4
sketch\uiconfig.h:152:0: warning: "UI_DISPLAY_CHARSET" redefined [enabled by default]
#define UI_DISPLAY_CHARSET 3
sketch\uiconfig.h:68:0: note: this is the location of the previous definition
sketch\uiconfig.h:187:0: warning: "UI_DISPLAY_RS_PIN" redefined [enabled by default]
#define UI_DISPLAY_RS_PIN _BV(4)
sketch\userpins.h:104:0: note: this is the location of the previous definition
#define UI_DISPLAY_RS_PIN 29
sketch\uiconfig.h:188:0: warning: "UI_DISPLAY_RW_PIN" redefined [enabled by default]
#define UI_DISPLAY_RW_PIN _BV(5)
sketch\userpins.h:105:0: note: this is the location of the previous definition
#define UI_DISPLAY_RW_PIN -1
sketch\uiconfig.h:189:0: warning: "UI_DISPLAY_ENABLE_PIN" redefined [enabled by default]
#define UI_DISPLAY_ENABLE_PIN _BV(6)
sketch\userpins.h:106:0: note: this is the location of the previous definition
#define UI_DISPLAY_ENABLE_PIN 27
sketch\uiconfig.h:190:0: warning: "UI_DISPLAY_D0_PIN" redefined [enabled by default]
#define UI_DISPLAY_D0_PIN _BV(0)
sketch\userpins.h:107:0: note: this is the location of the previous definition
#define UI_DISPLAY_D0_PIN -1
sketch\uiconfig.h:191:0: warning: "UI_DISPLAY_D1_PIN" redefined [enabled by default]
#define UI_DISPLAY_D1_PIN _BV(1)
sketch\userpins.h:108:0: note: this is the location of the previous definition
#define UI_DISPLAY_D1_PIN -1
sketch\uiconfig.h:192:0: warning: "UI_DISPLAY_D2_PIN" redefined [enabled by default]
#define UI_DISPLAY_D2_PIN _BV(2)
sketch\userpins.h:109:0: note: this is the location of the previous definition
#define UI_DISPLAY_D2_PIN -1
sketch\uiconfig.h:193:0: warning: "UI_DISPLAY_D3_PIN" redefined [enabled by default]
#define UI_DISPLAY_D3_PIN _BV(3)
sketch\userpins.h:110:0: note: this is the location of the previous definition
#define UI_DISPLAY_D3_PIN -1
sketch\uiconfig.h:194:0: warning: "UI_DISPLAY_D4_PIN" redefined [enabled by default]
#define UI_DISPLAY_D4_PIN _BV(0)
sketch\userpins.h:111:0: note: this is the location of the previous definition
#define UI_DISPLAY_D4_PIN 26
sketch\uiconfig.h:195:0: warning: "UI_DISPLAY_D5_PIN" redefined [enabled by default]
#define UI_DISPLAY_D5_PIN _BV(1)
sketch\userpins.h:112:0: note: this is the location of the previous definition
#define UI_DISPLAY_D5_PIN 25
sketch\uiconfig.h:196:0: warning: "UI_DISPLAY_D6_PIN" redefined [enabled by default]
#define UI_DISPLAY_D6_PIN _BV(2)
sketch\userpins.h:113:0: note: this is the location of the previous definition
#define UI_DISPLAY_D6_PIN 24
sketch\uiconfig.h:197:0: warning: "UI_DISPLAY_D7_PIN" redefined [enabled by default]
#define UI_DISPLAY_D7_PIN _BV(3)
sketch\userpins.h:114:0: note: this is the location of the previous definition
#define UI_DISPLAY_D7_PIN 23
In file included from sketch\ui.h:1141:0,
sketch\uilang.h:64:0: warning: "CHAR_RIGHT" redefined [enabled by default]
#define CHAR_RIGHT 187 //>>
sketch\uilang.h:24:0: note: this is the location of the previous definition
#define CHAR_RIGHT '-'
sketch\uilang.h:65:0: warning: "CHAR_SELECTOR" redefined [enabled by default]
#define CHAR_SELECTOR 255 //'>'
sketch\uilang.h:25:0: note: this is the location of the previous definition
#define CHAR_SELECTOR '>'
sketch\uilang.h:66:0: warning: "CHAR_SELECTED" redefined [enabled by default]
#define CHAR_SELECTED 254 //'*'
sketch\uilang.h:26:0: note: this is the location of the previous definition
#define CHAR_SELECTED '*'
sketch\uilang.h:67:0: warning: "STR_auml" redefined [enabled by default]
#define STR_auml "\344"
sketch\uilang.h:27:0: note: this is the location of the previous definition
#define STR_auml "ae"
sketch\uilang.h:68:0: warning: "STR_Auml" redefined [enabled by default]
#define STR_Auml "\304"
sketch\uilang.h:28:0: note: this is the location of the previous definition
#define STR_Auml "Ae"
sketch\uilang.h:69:0: warning: "STR_uuml" redefined [enabled by default]
#define STR_uuml "\374"
sketch\uilang.h:29:0: note: this is the location of the previous definition
#define STR_uuml "ue"
sketch\uilang.h:70:0: warning: "STR_Uuml" redefined [enabled by default]
#define STR_Uuml "\334"
sketch\uilang.h:30:0: note: this is the location of the previous definition
#define STR_Uuml "Ue"
sketch\uilang.h:71:0: warning: "STR_ouml" redefined [enabled by default]
#define STR_ouml "\366"
sketch\uilang.h:31:0: note: this is the location of the previous definition
#define STR_ouml "oe"
sketch\uilang.h:72:0: warning: "STR_Ouml" redefined [enabled by default]
#define STR_Ouml "\326"
sketch\uilang.h:32:0: note: this is the location of the previous definition
#define STR_Ouml "Oe"
sketch\uilang.h:73:0: warning: "STR_szlig" redefined [enabled by default]
#define STR_szlig "\337"
sketch\uilang.h:33:0: note: this is the location of the previous definition
#define STR_szlig "ss"
pins.h:374: error: 'PS_ON_PIN' was not declared in this scope
#define SENSITIVE_PINS {0, 1, X_STEP_PIN, X_DIR_PIN, X_ENABLE_PIN, X_MIN_PIN, X_MAX_PIN, Y_STEP_PIN, Y_DIR_PIN, Y_ENABLE_PIN, Y_MIN_PIN, Y_MAX_PIN, Z_STEP_PIN, Z_DIR_PIN, Z_ENABLE_PIN, Z_MIN_PIN, Z_MAX_PIN, LED_PIN, PS_ON_PIN, \
sketch\Commands.cpp:24:38: note: in expansion of macro 'SENSITIVE_PINS'
const int sensitive_pins[] PROGMEM = SENSITIVE_PINS; // Sensitive pin list for M42
sketch\Commands.cpp: In static member function 'static void Commands::executeGCode(GCode*)':
Commands.cpp:1100: error: 'PS_ON_PIN' was not declared in this scope
SET_OUTPUT(PS_ON_PIN); //GND
sketch\HAL.h:149:57: note: in definition of macro 'SET_OUTPUT'
#define SET_OUTPUT(pin) PIO_Configure(g_APinDescription[pin].pPort, PIO_OUTPUT_1, \
Commands.cpp:1101: error: 'setPowerOn' is not a member of 'Printer'
Printer::setPowerOn(true);
exit status 1
____________________________________________________________________________
But 0.92.9 without any problems, is poured into the controller and almost works as with Mega 2560.
The smooth printing of the circumference does not work and the extruder motor on the new R-H is not controlled.
For some reason, the user file does not have this data, and the board manufacturer does not respond.
But I assumed once in the user file of the pins there is not this data, then in Repetier-Firmware somewhere else is specified and they have a standard value.
Tell me please what numbers of pins?
Or where to watch them?
is the only error meaning your board did not set the pin. -1 would be a default to not have a power on pin at all. Add that to your board definition.
Yes error on PS_ON_PIN, but shows it in Commands.cpp
I have this setting in my - userpins.h
Has attached my firmware kit https://www.dropbox.com/s/3w3ogooh5ydsr58/RF_091_rv8.rar?dl=0
#define PS_ON_PIN -1
in your userpins.h and it should disappear.
But why bother with such an old firmware? Upgrade to 1.0.
Please send a link to the new firmware.
At 0.92.9, I have another problem, sometimes on some layer something strange happens.
Printing does not follow a toe-one, but as if from the point that it was before strangeness to the point in a few lines, while the extruder squeezes out all the plastic put for the missed place.
Layer 6 after the plateau - http://prntscr.com/ge25yx
Layer 10 after the plateau - http://prntscr.com/ge26zf
Layer 9 after the plateau - http://prntscr.com/ge27j0
Layer 10 (again) and layer 92 after the plateau - http://prntscr.com/ge27w8
Of the six attempts to print without such artifacts, only two were obtained.
The rest without any regularity received artifacts in completely different places.
Control program Р-H 2.0.5
http://prntscr.com/gekgv5
Formed a new firmware in the configurator.
The error was gone.
But now, when connected, the printer is busy processing.
motors do not respond to commands
07: 50: 07.171: Using fast VBOs for rendering is possible
07: 50: 09.731: wait
07: 50: 10.711: wait
07: 50: 11.021: No start signal detected - forcing start
07: 50: 11.051: N1 M110 * 34
07: 50: 11.051: N2 M115 * 36
07: 50: 11.051: N3 M105 * 36
07: 50: 11.051: N4 M114 * 35
07: 50: 11.051: N5 M111 S6 * 98
07: 50: 11.051: N6 T0 * 60
07: 50: 11.051: N7 M20 * 22
07: 50: 11.051: N8 M80 * 19
07: 50: 11.051: ok
07: 50: 11.061: ok 2
07: 50: 11.081: FIRMWARE_NAME: Repetier_1.0.0dev FIRMWARE_URL: https: //github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION: 1.0 MACHINE_TYPE: Mendel EXTRUDER_COUNT: 1 REPETIER_PROTOCOL: 3
07: 50: 11.081: N9 M220 S100 * 104
07: 50: 11.081: N10 M221 S100 * 81
07: 50: 11.081: N11 M111 S6 * 87
07: 50: 11.081: N12 T0 * 9
07: 50: 11.081: Cap: PROGRESS: 0
07: 50: 11.091: Cap: AUTOREPORT_TEMP: 1
07: 50: 11.091: N13 M155 S1 * 82
07: 50: 11.091: Cap: EEPROM: 0
07: 50: 11.091: Cap: AUTOLEVEL: 0
07: 50: 11.091: Cap: Z_PROBE: 0
07: 50: 11.091: Cap: SOFTWARE_POWER: 1
07: 50: 11.091: Cap: TOGGLE_LIGHTS: 0
07: 50: 11.091: Cap: PAUSESTOP: 1
07: 50: 11.101: Cap: PREHEAT: 1
07: 50: 11.101: PrinterMode: FFF
07: 50: 11.101: ok 3
07: 50: 11.131: T: 103.69 / 0 @: 0
07: 50: 11.131: ok 4
07: 50: 11.131: X: 0.00 Y: 0.00 Z: 0.000 E: 0.0000
07: 50: 11.131: ok 5
07: 50: 11.131: DebugLevel: 6
07: 50: 11.131: ok 6
07: 50: 11.131: SelectExtruder: 0
07: 50: 11.131: FlowMultiply: 100
07: 50: 11.131: ok 7
07: 50: 11.131: Begin file list
07: 50: 11.131: End file list
07: 50: 11.131: ok 8
07: 50: 11.131: ok 9
07: 50: 11.131: SpeedMultiply: 100
07: 50: 11.131: ok 10
07: 50: 11.131: ok 11
07: 50: 11.131: ok 12
07: 50: 11.131: ok 13
07: 50: 12.131: wait
07: 50: 12.181: T: 103.69 / 0 @: 0
07: 50: 13.131: wait
07: 50: 13.271: T: 103.69 / 0 @: 0
07: 50: 14.141: wait
07: 50: 14.371: T: 103.66 / 0 @: 0
07: 50: 15.141: wait
07: 50: 15.461: T: 103.66 / 0 @: 0
07: 50: 16.141: wait
07: 50: 16.551: T: 103.66 / 0 @: 0
07: 50: 17.141: wait
07: 50: 17.651: T: 103.66 / 0 @: 0
07: 50: 17.861: N14 G1 X10 F4800 * 14
07: 50: 17.871: ok 14
07: 50: 18.741: T: 103.66 / 0 @: 0
07: 50: 18.871: wait
07: 50: 19.831: T: 103.66 / 0 @: 0
07: 50: 19.871: wait
07: 50: 20.871: wait
07: 50: 20.921: T: 103.66 / 0 @: 0
07: 50: 21.651: N15 G1 Y10 F4800 * 14
07: 50: 21.651: ok 15
07: 50: 22.021: T: 103.66 / 0 @: 0
07: 50: 22.651: wait
07: 50: 23.111: T: 103.66 / 0 @: 0
07: 50: 23.651: wait
07: 50: 24.201: T: 103.66 / 0 @: 0
07: 50: 24.651: wait
07: 50: 25.301: T: 103.66 / 0 @: 0
07: 50: 25.651: wait
07: 50: 25.961: N16 G28 * 36
07: 50: 25.961: ok 16
07: 50: 26.391: T: 103.66 / 0 @: 0
07: 50: 27.481: T: 103.63 / 0 @: 0
07: 50: 27.961: busy: processing
07: 50: 28.581: T: 103.63 / 0 @: 0
07: 50: 29.671: T: 103.66 / 0 @: 0
07: 50: 29.961: busy: processing
07: 50: 30.761: T: 103.63 / 0 @: 0
07: 50: 31.851: T: 103.63 / 0 @: 0
07: 50: 31.961: busy: processing
07: 50: 32.951: T: 103.63 / 0 @: 0
07: 50: 33.961: busy: processing
07: 50: 34.041: T: 103.63 / 0 @: 0
07: 50: 35.131: T: 103.63 / 0 @: 0
07: 50: 35.961: busy: processing
07: 50: 36.231: T: 103.63 / 0 @: 0
07: 50: 37.321: T: 103.63 / 0 @: 0
07: 50: 37.961: busy: processing
07: 50: 38.411: T: 103.63 / 0 @: 0
07: 50: 39.501: T: 103.63 / 0 @: 0
07: 50: 39.961: busy: processing
Another thermistor of the extruder for some reason shows 103.63 degrees. should be room temperature.
I have a 104GT-2
I assume the wrong ADC
On 0.92.9 everything was correct.
Where can I fix the ADC?
is formed as m Marlin?
If not then send the instruction.
Only temperature is wrong. First make sure temperature changes when heating so you know it is using the sensor at all. Also make sure you have used a thermisor input and not a thermocouple input! Unplug themistor and measure resistance at room temperature - should be around 100K (100K exact for 25°C). If not it is defect.
The commands from 0.92.9 respond.
The truth is that in P-H in other control programs like Simplify3D 4.0.0 the extruder motor is not controlled.
Repair this moment.
Because with firmware 1.0.0 does not control the motors from any control program at all.
Since latest dev update extruder will move even in illegal positions with pure e moves.
