uniconfig.h custom buttons
I would like to add some custom buttons.
1. Button that starts autolevel
2. Button that turns the CASE_LIGHTS_PIN on
3. Button that executes a particular gcode file (not just recently seleced)
I have looked at the long list of options at top of ui.h but I just don't see how to do it.
uint8_t Printer::moveToReal(float x,float y,float z,float e,float f,bool pathOptimize = true);
Set coordinates to IGNORE_COORDINATE it you do not want to change.
One button can only have one function. What you want in this case is a wizard where you switch between wizard pages with "ok" and action is bound to ok. But that is a bit more difficult to program and requires some programming skills to understand the flow. See filament change for an example.
since I use zprobe autoleveling instead of software leveling, I was able to repurpose setp1-setp3. in hindsight, I probably could have left the prev code in place alongside what I have below and it still would have worked.
I also made a P123_RESET UI_ACTION to change all my probe points back to normal. I know I could use the code from M502, but too many other things in the eeprom also get reset with that, and it's not always convenient. If I wasn't so lazy I would figure out how to make space in the eeprom and store the original data there, that way these values wouldn't have to manually adjusted for each persons printer.
case UI_ACTION_SET_P1SA:
Having a button that resets that "Printing time" and "Filament Printed" counters on the LCD has come in handy. I press it before starting a print and I get accurate counts for that print. The counter for a print usually goes away as soon as it finishes, and I don't usually keep my repetier host connected to monitor the time. Nor can I be relied upon to write down or remember the time a print starts (or notice when it finishes). But I can press a button. ...
Z-Probe Servo Deploy and Retract buttons. Is there a a way to have it toggle between these two function on one button?
case UI_ACTION_ZPROBE_DEPLOY:
boolean flag= FALSE ; // at beginning of your custom events, must be global defined
case x:
if(!flag) {
action = action1;
flag= TRUE;
else{
action = action2;
flag= FALSE;
break;
something like this should work
