Extruder spins on print start after warm up
Hello,
For some reason my Prusa i3 Reprap printer with the latest Repeiter firmware will most of the time - start spinning the extruder for minutes before it moves the print head to the appropriate position after the bed and extruder hotend have reached the set tempurature.  If I kill the print job (resetting the Ardunio) and restart the print then it seems fine.  Not sure what to make of it.  Can anyone help out?
  • edited April 2015
    Might be related to these setting (also in eeprom present)
    /** \brief Temperature to retract filament when extruder is heating up. Overridden if EEPROM activated.
    /** \brief Units (mm/inches) to retract filament when extruder is heating up. Overridden if EEPROM activated. Set
    to 0 to disable.
  • Hello,  My units setting was #define EXT0_WAIT_RETRACT_UNITS 500.  I have set it to zero and will see what happens.
  • Remember it might also be in eeprom overriding your setting!
