TEVO Tarantula Repetier Fail
when ever I print the Firmware prints about half the Print and then goes into "DRY Run Mode" No matter what I do I cannot get out of it I try a Reset and then try the print agai with the same results... I am Using slicer nor Skenforge or Curia because of my Lack of success with the programs.
I am De-baiting going back to Sprinter seven though I will have to have it connected to a serial connection to print AT LEAST IT WORKS.
"14:34:10.902 : N6803 G1 X76.428 Y105.998 E30.68739*92
14:34:11.061 : ok 6803
14:34:11.062 : N6804 G1 X76.428 Y104.828 E30.74851*92
14:34:11.157 : ok 6804
14:34:11.255 : N6805 G1 X80.98 Y104.828 E30.98635*101
14:34:11.269 : ok 6805
14:34:11.271 : N6806 M104 T0 S0*25
14:34:11.272 : N6807 M140 S0*92
14:34:11.272 : N6808 M84*41
14:34:11.309 : ok 6806
14:34:11.309 : Other:: working marked decoupled
14:34:11.309 : heated bed: working
14:34:11.309 : Error:Printer set into dry run mode until restart!
14:34:11.309 : ok 6807
14:34:11.309 : ok 6808
14:34:11.683 : N6809 M105*16
14:34:12.748 : T:132.38 /0 B:89.32 /0 B@:0 @:0
14:34:12.748 : ok 6809
14:34:12.761 : T:132.29 /0 B:89.28 /0 B@:0 @:0
14:34:13.751 : wait
14:34:14.744 : N6810 M105*24
14:34:14.757 : ok 6810
14:34:14.759 : T:130.50 /0 B:88.98 /0 B@:0 @:0
Here is the code and Dry run mode I know is off.
