connection green - tested all baud rates, but no start
I've tried all baud rates available under the Repetier printer settings, but no start was acked, all the log files states that there was no start signal detected and it will force a start.
I have the Melzi v2.0 hardware and since the printer info is unknown, I can't specify the firmware version
Please help
Thanks in advance =]
  • Some printers need special settings for reset on connect to work properly. Please also vary this while leaving protocol to autodetect.
    Are you sure you have installed a firmware on your board?
  • I bought a kit, but I open config. firmware eeprom show a list with
    baudrate 76800 and  a x,y,z,e  parameters, but I dont know if it is correct or what I have to do.
