Repetier Host 2.01 crashes after server shutdown
More often than not when I do a 'server shutdown' from the menu Reptier Host will ask if I'm sure, after selecting Yes, will disconnect and shutdown the server and then it will freeze RH for a moment before I get an error message: "RepetierHost has stopped working. A problem caused the program to stop etc etc". Then the program exits.
I'm running RH V2.01 on Win 10 and the server on a Raspberry Pi3 V0.85.0
Or do you mean shutdown in the raspberry frontend while connected to host?
If it persists in 2.0.2 let me know so I can dig deeper.
