Repetier Host 2.01 crashes after server shutdown
More often than not when I do a 'server shutdown' from the menu Reptier Host will ask if I'm sure, after selecting Yes, will disconnect and shutdown the server and then it will freeze RH for a moment before I get an error message: "RepetierHost has stopped working.  A problem caused the program to stop etc etc".  Then the program exits.
I'm running RH V2.01 on Win 10 and the server on a Raspberry Pi3 V0.85.0
  • You can not shutdown the server from Repetier-Host if it is not running on the same machine (Stop local server). So this means you are shutting down the server on your windows machine and not the one on the Raspberry!
    Or do you mean shutdown in the raspberry frontend while connected to host?
  • I am not trying to stop the local server (it's not running anyway).   Repetier Host is connected to Repetier Server in the printer settings using the Pi's IP address / Port 3344 and the API key.  So, from Repetier Host, when I go to Printer > Shutdown Server, after answering Yes to 'Really shutdown server'  it crashes Repetier Host.
  • Ok, I understand. So the unexpected disconnect seems to cause the crash. Unfortunately I can not reproduce it. I get a message that the IP is not available any more, connection is closed and I can continue. Does the error window contain any more details? If not windows events should show more infos on the crash. Will keep an eye on it and try some more times, but it might also depend on some other conditions I do not meet.
  • Here's the Windows event error logs and screenshot....
    Log Name:      Application
    Source:        .NET Runtime
    Date:          21/07/2017 20:46:18
    Event ID:      1026
    Task Category: None
    Level:         Error
    Keywords:      Classic
    User:          N/A
    Computer:      Paul-Desktop
    Description:
    Application: RepetierHost.exe
    Framework Version: v4.0.30319
    Description: The process was terminated due to an unhandled exception.
    Exception Info: System.AccessViolationException
       at OpenTK.Graphics.OpenGL.GL.DeleteBuffers(Int32, Int32[])
       at RepetierHost.model.GCodePath.UnbufferVBOs()
       at RepetierHost.model.GCodePath.Free()
       at RepetierHost.model.GCodeVisual.Clear()
       at RepetierHost.Main.ClearPrintPreview()
       at RepetierServerConnector.ServerConnector.Connect(Boolean)
       at RepetierServerConnector.ServerConnector.RunPeriodicalTasks()
       at RepetierHost.model.PrinterConnection.handleTimer(System.Object, System.EventArgs)
       at System.Timers.Timer.MyTimerCallback(System.Object)
       at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
       at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
       at System.Threading.TimerQueueTimer.CallCallback()
       at System.Threading.TimerQueueTimer.Fire()
       at System.Threading.TimerQueue.FireNextTimers()
    Event Xml:
      <System>
        <Provider Name=".NET Runtime" />
        <EventID Qualifiers="0">1026</EventID>
        <Level>2</Level>
        <Task>0</Task>
        <Keywords>0x80000000000000</Keywords>
        <TimeCreated SystemTime="2017-07-21T19:46:18.235256200Z" />
        <EventRecordID>10356</EventRecordID>
        <Channel>Application</Channel>
        <Computer>Paul-Desktop</Computer>
        <Security />
      </System>
      <EventData>
        <Data>Application: RepetierHost.exe
    </Data>
      </EventData>
    </Event>
    Source:        Application Error
    Date:          21/07/2017 20:46:19
    Event ID:      1000
    Task Category: (100)
    Level:         Error
    Keywords:      Classic
    User:          N/A
    Description:
    Faulting application name: RepetierHost.exe, version: 1.0.0.0, time stamp: 0x5910a761
    Faulting module name: ig75icd64.dll, version: 20.19.15.4531, time stamp: 0x57ed2465
    Exception code: 0xc0000005
    Fault offset: 0x0000000000743a2e
    Faulting process ID: 0x1834
    Faulting application start time: 0x01d30248f0475886
    Faulting application path: C:\Program Files\Repetier-Host\RepetierHost.exe
    Faulting module path: C:\WINDOWS\SYSTEM32\ig75icd64.dll
    Report ID: 8be252e3-d6ec-40fe-a525-bcb29bc461e5
    Faulting package full name:
    Faulting package-relative application ID:
    Event Xml:
      <System>
        <Provider Name="Application Error" />
        <EventID Qualifiers="0">1000</EventID>
        <Level>2</Level>
        <Task>100</Task>
        <TimeCreated SystemTime="2017-07-21T19:46:19.250567000Z" />
        <EventRecordID>10357</EventRecordID>
        <Security />
      </System>
      <EventData>
        <Data>RepetierHost.exe</Data>
        <Data>1.0.0.0</Data>
        <Data>5910a761</Data>
        <Data>ig75icd64.dll</Data>
        <Data>20.19.15.4531</Data>
        <Data>57ed2465</Data>
        <Data>c0000005</Data>
        <Data>0000000000743a2e</Data>
        <Data>1834</Data>
        <Data>01d30248f0475886</Data>
        <Data>C:\Program Files\Repetier-Host\RepetierHost.exe</Data>
        <Data>C:\WINDOWS\SYSTEM32\ig75icd64.dll</Data>
        <Data>8be252e3-d6ec-40fe-a525-bcb29bc461e5</Data>
        <Data>
        </Data>
        <Data>
        </Data>
      </EventData>
    </Event>
  • Ok, I see it happens in freeing OpenGL resources. I also see that this path may be executed outside main thread which could be a problem. So for next release 2.0.2 I have now ensured this will run in main thread instead.
    If it persists in 2.0.2 let me know so I can dig deeper.
  • Will do - when is 2.0.2 going to be released?  Keep up the good work!
  • Very soon. more or less finished and only running some tests to verify it works as expected.
  • There's still an issue in V2.0.5.  After server shutdown and confirmation, RH just sits there with a 'Not Responding' message.  Event Viewer doesn't log anything until I force close the program and just shows an application hang message.
  • Did you wait long enough? It might take a while until host detects the connection is down and it will try even to reconnect. So you get here some blocking until network times out and returns failed connect. Had this at least with wrong ips and it can take a bit until it responds again.
  • I waited about 4 to 5 minutes before I closed the program....
