z-Axis too slow
my Z-Axis ist too slow.
Changing steps and feedrate does not help.
Nothing is changing in working.
All other parameters are working. Only the z-Axis not
Are you changing values in the config.h or direct eeprom editing ?
yes, i changed in config.h
increase that setting as its limiting speed
you need to send the following codes to the printer to update eeprom with new config settings
M502 ;reads config
M500 ;stores too eeprom
or use the eeprom editor in repetier host
