Using different extruders with different filament diameter results in "unexpected" results.
Steps to reproduce:
Use following extruder settings:
extruder 0: diameter 3mm, extrusion multiplier 1.1
extruder 1: diameter 1.75mm, extrusion multiplier 1.2
Insert to "Printer Settings"/"Custom G-Code":
; filamentDiameter=[filament_diameter]
; filamentDiameter0=[filament_diameter_0]
; filamentDiameter1=[filament_diameter_1]
; filamentDiameter2=[filament_diameter_2]
; filamentDiameter3=[filament_diameter_3]
; extrusionMultiplier=[extrusion_multiplier]
; extrusionMultiplier0=[extrusion_multiplier_0]
; extrusionMultiplier1=[extrusion_multiplier_1]
; extrusionMultiplier2=[extrusion_multiplier_2]
; extrusionMultiplier3=[extrusion_multiplier_3]
Slice one object (no special settings in "multiple extruder" - only one extruder shall be used for print)
Results are ... errrrr ... unexpected:
; filamentDiameter=3
; filamentDiameter0=3
; filamentDiameter1=7
; filamentDiameter2=1.75
; filamentDiameter3=7
; extrusionMultiplier=1.1
; extrusionMultiplier0=1.1
; extrusionMultiplier1=1.2
; extrusionMultiplier2=1.1
; extrusionMultiplier3=1.1
i got multipliers korrekt but diameters wrong! "7"???? what the hell?
As a result only printing with 1st extruder is working in this case - the second extruder always is configured with diameter of 7.
Regards,
tps42
Slic3r: 1.3.0-dev, 1.2.9 (all version i tried)
Repetierhost: 2.0.1
Which is correct. Not sure what you did wrong. But make sure to use . and not , for numbers. Slic3r uses , to separate the values in the list so wrong usage might confuse the slicer resulting in wrong values.
You also could look into the resulting slic3r_settings.ini in host workdirectory used for slicing. In may case you find
Which is what you need to get the wanted result.
I was able to track down the problem towards a buggy filament-/extruder-profile that contains
this one triggers the above behavior. The question that arises from this as it nearly drove me nuts:
Why does slic3r accept a filament.ini that contains this rubbish?
Why does slic3r hide the real value within the GUI? (in GUI you can only see the "3") Even when the buggy profile is edited (even when diameter is changed) and saved the ",7" still persists within the .ini !!!
So could the title of my bug-report become "Slic3r accepts multiple extruder diameters within single extruder profile"?
it took me quite a long time to get to the root cause here... so probably not a bug but a feature request?
