Rambo Board Y Stepper Failing sporadically after going from 12V to 24V
Hi all,
I have a rather anoying problem with my Makergear M2 after going from 12V to 24V.
The Y Stepper sometimes does not receive steps, even with very slow speeds, so I am sure it is not a problem of insufficient torque.
I also lowered the voltage and added a fan for cooling.
I changed the stepper driver, and checked all mechanical components.
The sad thing is everything worked fine on 12V, the errors startet with 24V.
I even got the newest Rambo in the meantime (mine was 1.0) and still had failed prints from time to time...
Another curious side fact, I had the same problem on another Makergear M2 with Rambo on 12V at my workplace, but there the problem went away after changing from a PC (Repetier Host) to a Raspberry Pi (Octoprint) for Inputs.
Everythings works fine with Marlin! But for various reasons I'd like to use repetier firmware.
Does anybody have an idea?
Regards
Lukas
Regards
Lukas
An othe rsolution would by to connect Y axis to anouther stepper e.g. second extruder. If you need second extruder as well connect that to y stepper then. If dropouts are short is not as bad as misaligned prints.
Should I try stepper high delay?
One thing with Rambo board is that motor current is set in software. Maybe you need to reduce it now that you doubled voltage? If Marlin has lower defaults it would explain that they had no problems. If you go too high the drivers might get hot and disable for short times.
I already lowered the current, attached heatsinks to the driver (only the Y socket) and used a 50mm fan.
Drivers don't seem to get too hot, and the error is not repeatable, sometimes I had no problems for 2 weeks, than multiple failed prints in 2 days.
