Catching knob input in UI wizard
Hi guys,
I think I migh need your help again. I'm implementing a wizard to level the bed manually. Basically it's exactly the same as the Ultimaker 2 routine for manual levelling. I've made a wizard menu:
[code]
UI_WIZARD4_T(ui_wiz_bed_level, UI_ACTION_WIZARD_BED_LEVEL, UI_TEXT_WIZ_BED_LEVEL1_ID, UI_TEXT_WIZ_BED_LEVEL2_ID, UI_TEXT_WIZ_BED_LEVEL3_ID, UI_TEXT_WIZ_BED_LEVEL4_ID) UI_WIZARD4_T(ui_wiz_manual_probe, UI_ACTION_WIZARD_BED_LEVEL, UI_TEXT_WIZ_MANUAL_PROBE1_ID, UI_TEXT_WIZ_MANUAL_PROBE2_ID, UI_TEXT_WIZ_MANUAL_PROBE3_ID, UI_TEXT_WIZ_MANUAL_PROBE4_ID)
[/code]
I also added an entry for bed leveling wizard in the configurations menu with the standard method described in uimenu.h
Then, in ui.cpp I try to "catch" the input of the diplay knob. However, I can't find any guide on how to do this. Copying pieces of code from eg [code]case UI_ACTION_XPOSITION_FAST:[/code] only gives me errors and I can't even leave the menu!
Can somebody please point me towards a custom wizard tutorial? I'm really stuck here.
[code]
[/code]
UI_ACTION_WIZARD_FILAMENTCHANGE and you will find it in 3 case sections. One for activated, know turned and knob pressed. That should give you all cases you need.
