Touchscreen and hostname
I have Repetier Server Pro (Image V7 with Repetier-Server 0.85.1) on a Raspberry Pi 2 with a touchscreen (Waveshare 7’’ HDMI LCD (C) rev 2.1).
Initially, everything is working perfectly, both image and touch function, but when I change the hostname (via raspi-config), and after reboot, the following message appears:
If I choose “Quit” the screen goes to gray and remains until a reboot, which shows again the same message.
If I choose “Unlock Profile and Relaunch”, the server’s screen shows correctly, but when I attempt to tap on any button, it starts to make strange things: zooming in/out, tap on a button and another activates instead …
Sorry if the fix for this is obvious, but I do not know much of Linux.
Thanks.
If it is chrome you can delete the cache
rm -r /home/pi/.cache/chromium
sudo reboot
I already tried calibrating the screen before opening the discussion, but that did not fix it.
After I entered “rm -r /home/pi/.cache/chromium” and rebooted, the message box still showed but this time, after selecting “Unlock Profile and Relaunch” the touchscreen works correctly, so, it seems it is fixed.
Thanks.
