How to shut down the printer on print finish
So I have one of these fancy smart plugs. I intercepted its traffic and now I know what rest commands i need to send to shut it down and turn it on.
What I wanted to do is create a small python script that would poll the message directory and scan for "print finished" messages so it knows when it should shut down, after a timer.
I guess all I really need to know is where can I find these messages on repetier server on the raspberry pi?
  • Not so complicated!
    See manual how to add extcommands.xml file for external commands allowed. With that you can have a server command
    @execute shutdown
    whcih calls your script. Then go printer settings->g-codes->event dependent and add that gcode in the run after job event as last command.
  • This is brilliant, thank you.
  • Hi guys,
    I am trying to do the same thing but am a little new to this.  Would it be possible please to elaborate some more about what needs to be done to implement this functionality?
    Many thanks in advance.
    Cheers
    Dan
  • Please read the "Advanced Setup" part in server manual (best after upgrading to 0.85.1 where it was fixed a bit). If you then have special questions let us know.
