Z-Correction not working properly on delta
I followed the video guide on using G32 and G33 to level the bed on a delta. However, regardless of whether z-correction is applied, my height map looks like this:
Here are the height map text results:
And here are the results (including the offset amount) from G33:
Am I missing something where you have to apply the offsets? Thanks.
X: -65.00 -32.50 0.00 32.50 65.00
y:65.00 40.00 40.01 40.04 40.00 40.00
y:32.50 40.01 40.00 39.99 40.03 40.00
y:0.00 40.01 40.00 40.01 40.01 40.01
y:-32.50 39.96 40.00 39.99 39.96 39.98
y:-65.00 38.61 39.98 40.04 40.01 40.00
00:40:38.418 : Z-probe:38.61 X:-65.00 Y:-65.00 zCorr:0.04
00:40:39.947 : Z-probe:39.98 X:-32.50 Y:-65.00 zCorr:-0.20
00:40:41.539 : Z-probe:40.04 X:0.00 Y:-65.00 zCorr:-0.34
00:40:43.135 : Z-probe:40.01 X:32.50 Y:-65.00 zCorr:-0.41
00:40:43.711 : X:32.50 Y:-65.00 Z:40.000 E:0.0000
00:40:44.283 : Z-probe:40.00 X:32.50 Y:-65.00 zCorr:-0.41
00:40:46.775 : Z-probe:39.96 X:-65.00 Y:-32.50 zCorr:-0.26
00:40:48.360 : Z-probe:40.00 X:-32.50 Y:-32.50 zCorr:-0.24
00:40:49.950 : Z-probe:39.99 X:0.00 Y:-32.50 zCorr:-0.36
00:40:51.543 : Z-probe:39.96 X:32.50 Y:-32.50 zCorr:-0.41
00:40:53.138 : Z-probe:39.98 X:65.00 Y:-32.50 zCorr:-0.36
00:40:56.022 : Z-probe:40.01 X:-65.00 Y:0.00 zCorr:-0.33
00:40:57.613 : Z-probe:40.00 X:-32.50 Y:0.00 zCorr:-0.29
00:40:59.202 : Z-probe:40.01 X:0.00 Y:0.00 zCorr:-0.26
00:41:00.791 : Z-probe:40.01 X:32.50 Y:0.00 zCorr:-0.30
00:41:02.383 : Z-probe:40.01 X:65.00 Y:0.00 zCorr:-0.34
00:41:05.266 : Z-probe:40.01 X:-65.00 Y:32.50 zCorr:-0.27
00:41:06.852 : Z-probe:40.00 X:-32.50 Y:32.50 zCorr:-0.20
00:41:08.432 : Z-probe:39.99 X:0.00 Y:32.50 zCorr:-0.15
00:41:10.013 : Z-probe:40.03 X:32.50 Y:32.50 zCorr:-0.17
00:41:11.600 : Z-probe:40.00 X:65.00 Y:32.50 zCorr:-0.31
00:41:12.171 : X:65.00 Y:32.50 Z:40.000 E:0.0000
00:41:12.740 : Z-probe:40.00 X:65.00 Y:32.50 zCorr:-0.31
00:41:15.224 : Z-probe:40.01 X:-32.50 Y:65.00 zCorr:-0.11
00:41:16.802 : Z-probe:40.04 X:0.00 Y:65.00 zCorr:-0.10
00:41:18.382 : Z-probe:40.00 X:32.50 Y:65.00 zCorr:-0.19
00:41:18.949 : X:32.50 Y:65.00 Z:40.000 E:0.0000
00:41:19.523 : Z-probe:40.00 X:32.50 Y:65.00 zCorr:-0.19
(Increased to 10x10 points)
Even if the maximum is set to 30, the first point it probes is ~38.5
It seems like only an issue with the bed map, but actual prints show an error in that general area as well. Regardless of how many times I run correction, the bed map continues to show that error along with actual prints:
Thanks for the help, this is the closest I've gotten to a working printer in weeks!
Also, is there any way to probe the whole bed as shown below, because I currently have the largest square I can within the circular build plate and I think it may be ignoring some pretty crucial areas.
Thanks again!
