store current position to eeprom
My idea is to add three additional M codes
1-store current position ( X , Y ,Z) to eeprom and store it as position N for example
maybe the code can look like this : M** S1
as S 1 means store to position 1 (i think 3 positions will be enough )
2-show the stored coordinates in position N for example sending M*** S1 will send the coordinates stored in position and will show M*** S1 x... y... z...
3-move to position N for example sending M**** S1 will move the printer to coordinates stored in position 1
I think this will help a lot when using Repetier for cnc routing (for storing zero points and other necessary points) or for example to store the position while layer change so we can resume a print if the printer powered off accidentally
actually I tried to find out how to add eeprom addresses to the firmware and add new M codes and make this idea but I think I don't have enough programming skills to do this yet
I hope you can help me doing this or maybe you can start the development of this idea and I can help with trying on my printer or what ever I can do to help
And finally Thank you a lot for your works with all this flexible and reliable firmware ...
if it´s fixed positions you can use scripts from host.
to add new M-codes you can use the Custom event system.
see development branch on Github
any way thank you for your answer and I will check out how to make new custom event
