Tilting mechanism for dual hotend on a Delta printer
wandering if there is a simple gcode for a small servo or stepper to tilt the two hot ends placed on the effector when extruders change in gcode as new material is required/deposited...? and how to go about it...
Or how do ypu guys solve the problem that two hotends dont interfire with eachother without crazy z calibration(almost impossible). all videos i've seen have some sort of gimble system...
thanks
The most simple solution is to have a fixed bed and go with hotends to bed, make them loose let them fall to bed and fix them. Then they have same tilt as bed and you only need to new z probe height.
Nad as always you can choose whcih problems you like to have:-) Same level = cold ooze can drag object, tilt mechanism needs power on startup to adjust ad beginning already as this can only tilt with power. Y nozzle with 2 to 1 reduction not allowing different materials.
