Teacup firmware problem with Temp thermiston in Repetier-Host
Hi
i am experimenting with teacup firmware and uno board
The problem is that Repetier-Host doesn't saw the extruder temp... is always 0c
in the other hand when i connect my board to Pronterface i am getting the right readings
also when i send the M105 command in the Repetier nothing happens
any Help
Thanks in advance
any Help
Thanks in advance
Also I remember that when I connect the board to Repetier-Host it says bad M command 111,
bad M command 80
bad M command 20
I will check them all the above later day that I will be infront the machine
This is from the log in Repetier-host. As i can see it can read the temperature right in the log but doesnt display it in the ''manual control'' graphic panel where the extruder is
'' 08:21:55.440 : start
08:21:55.552 : N1 M110*34
08:21:55.552 : N2 M115*36
08:21:55.552 : N3 M105*36
08:21:55.553 : N4 M114*35
08:21:55.563 : ok
08:21:55.563 : ok
08:21:55.566 : N5 M111 S6*98
08:21:55.567 : N6 T0*60
08:21:55.567 : N7 M20*22
08:21:55.568 : N8 M80*19
08:21:55.568 : N9 M105*46
08:21:55.590 : N10 M111 S6*86
08:21:55.590 : ok
08:21:55.590 : ok
08:21:55.590 : N11 T0*10
08:21:55.595 : T:0.0/0.0
08:21:55.595 : ok
08:21:55.595 : ok
08:21:55.600 : ok
08:21:55.600 : ok
08:21:55.606 : ok
08:21:55.606 : ok
08:21:55.607 : ok
08:21:55.607 : ok
08:21:55.611 : ok
08:21:55.611 : ok
08:21:55.616 : rs N8 Expected checksum 97
08:21:55.616 : ok
08:21:55.616 : ok
08:21:55.616 : ok
08:21:55.621 : ok
08:21:55.621 : ok
08:21:58.653 : N12 M105*20
08:21:58.662 : T:22.50/0.0
08:21:58.663 : ok
08:21:58.663 : ok
08:22:01.654 : N13 M105*21
08:22:01.664 : T:22.0/0.0
08:22:01.664 : ok
08:22:01.664 : ok
08:22:04.656 : N14 M105*18
08:22:04.665 : T:21.50/0.0
08:22:04.665 : ok
08:22:04.665 : ok
08:22:07.658 : N15 M105*19
08:22:07.667 : T:22.50/0.0
08:22:07.667 : ok
08:22:07.667 : ok
08:22:10.659 : N16 M105*16
08:22:10.668 : T:23.25/0.0
08:22:10.669 : ok
08:22:10.669 : ok
08:22:13.661 : N17 M105*17
08:22:13.670 : T:23.25/0.0
08:22:13.670 : ok
08:22:13.670 : ok
08:22:16.663 : N18 M105*30
08:22:16.672 : T:23.25/0.0
08:22:16.672 : ok
08:22:16.672 : ok
08:22:19.665 : N19 M105*31
08:22:19.675 : T:23.25/0.0
08:22:19.675 : ok
08:22:19.675 : ok
08:22:22.667 : N20 M105*21
08:22:22.675 : T:22.50/0.0
08:22:22.675 : ok
08:22:22.676 : ok
08:22:24.972 : N21 M105*20
08:22:24.983 : T:23.25/0.0
08:22:24.983 : ok
08:22:24.983 : ok
08:22:25.668 : N22 M105*23
08:22:25.677 : T:23.25/0.0
08:22:25.677 : ok
08:22:25.678 : ok
08:22:28.670 : N23 M105*22
08:22:28.679 : T:22.50/0.0
08:22:28.679 : ok
08:22:28.679 : ok
08:22:31.672 : N24 M105*17
08:22:31.682 : T:23.25/0.0
08:22:31.682 : ok
08:22:31.682 : ok
08:22:34.673 : N25 M105*16
08:22:34.683 : T:23.25/0.0
08:22:34.683 : ok
08:22:34.683 : ok
08:22:37.675 : N26 M105*19
08:22:37.684 : T:23.25/0.0
08:22:37.684 : ok
08:22:37.685 : ok
08:22:40.678 : N27 M105*18
08:22:40.688 : T:23.25/0.0
08:22:40.688 : ok
08:22:40.688 : ok
08:22:43.679 : N28 M105*29
08:22:43.690 : T:23.25/0.0
08:22:43.690 : ok
08:22:43.690 : ok
08:22:46.682 : N29 M105*28
08:22:46.691 : T:22.0/0.0
08:22:46.691 : ok
08:22:46.691 : ok
08:22:49.683 : N30 M105*20
08:22:49.693 : T:19.75/0.0
08:22:49.693 : ok
08:22:49.693 : ok
08:22:52.685 : N31 M105*21
08:22:52.694 : T:22.0/0.0
08:22:52.694 : ok
08:22:52.695 : ok
''>>> m105
SENDING:M105
T:21.50/0.0
and here if i place a target for the hotend
Setting hotend temperature to 185.000000 degrees Celsius.
>>> m105
SENDING:M105
T:22.50/185.0
10:28:18.778 : ok
10:28:20.670 : N17 M104 T0 S200*21
10:28:20.679 : ok
10:28:20.679 : ok
10:28:21.769 : N18 M105*30
10:28:21.778 : T:24.25/200.0
10:28:21.778 : ok
10:28:21.778 : ok
10:28:24.770 : N19 M105*31
10:28:24.780 : T:23.75/200.0
10:28:24.780 : ok
10:28:24.781 : ok
10:28:27.772 : N20 M105*21
10:28:27.782 : T:23.25/200.0
10:28:27.782 : ok
10:28:27.782 : ok
10:28:30.775 : N21 M105*20
10:28:30.783 : T:23.25/200.0
10:28:30.784 : ok
10:28:30.784 : ok
10:28:33.777 : N22 M105*23
10:28:33.788 : T:22.50/200.0
10:28:33.788 : ok
10:28:33.788 : ok
10:28:36.778 : N23 M105*22
10:28:36.788 : T:23.25/200.0
But still i dont get no graphical readings in the ''manual control'' panel
T:23.25/200.0
becomes
T:23.25 /200.0
then it shoudl show graph. SHould be not hard to add the space in teacup. For next release I try to read also the wrong(non standard) output format.
even i dont have any background of studies in programming i manage to find the right file and alter the code
now thanks to your help the repetier host can read the values
this is a post for feature reference if any one has the same problem
the file that should open in an editor in the teacup folder is the ''temp.c''
and in the line 619-620 :
#ifdef REPORT_TARGET_TEMPS
sersendf_P(PSTR("/"));
have to add a space before /
be like that :
sersendf_P(PSTR(" /"));
then compile and will work just fine
