Fan does not automatically turn on
i can manually turn on the fan using repetier host, however the fan does not automatically turn on, i have looked at the config.h file however everything looks ok. Is there anything i'm overlooking?
I'm using:
- Arduino mega2560
- Fan is connected to D9
configuration.h below
along with Repetier-Firmware. If not, see .
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
generator: http://www.repetier.com/firmware/v092/
as you expect.
#define NUM_EXTRUDER 1
#define MOTHERBOARD 33
#include "pins.h"
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define BOARD_FAN_SPEED 255
#define FAN_THERMO_PIN -1
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL -1
#define BLUETOOTH_BAUD 115200
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 3
#define XAXIS_STEPS_PER_MM 80
#define YAXIS_STEPS_PER_MM 80
#define ZAXIS_STEPS_PER_MM 80
#define PDM_FOR_EXTRUDER 1
#define PDM_FOR_COOLER 1
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 370
#define EXT0_INVERSE 0
#define EXT0_ENABLE_ON 0
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 50
#define EXT0_HEAT_MANAGER 3
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 10
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 0
#define HAVE_HEATED_BED 0
#define SKIP_M190_IF_WITHIN 3
#define HEATED_BED_HEATER_PIN -1
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 275
// ## Laser configuration ##
automatically disabled.
#define SUPPORT_LASER 0
#define LASER_PIN ORIG_FAN_PIN
#define LASER_ON_HIGH 1
// ## CNC configuration ##
#define SUPPORT_CNC 0
#define CNC_WAIT_ON_DISABLE 0
#define CNC_ENABLE_PIN -1
#define CNC_ENABLE_WITH 1
#define CNC_DIRECTION_PIN -1
#define CNC_DIRECTION_CW 1
// ## Endstop configuration ##
/* By default all endstops are pulled up to HIGH. You need a pullup if you
use a mechanical endstop connected with GND. Set value to false for no pullup
on this endstop.
//set to true to invert the logic of the endstops
#define ENDSTOP_X_MAX_INVERTING true
#define ENDSTOP_Y_MAX_INVERTING true
#define ENDSTOP_Z_MAX_INVERTING true
// Set the values true where you have a hardware endstop. The Pin number is taken from pins.h.
//If your axes are only moving in one direction, make sure the endstops are connected properly.
//If your axes move in one direction ONLY when the endstops are triggered, set ENDSTOPS_INVERTING to true here
//// ADVANCED SETTINGS - to tweak parameters
// For Inverting Stepper Enable Pins (Active Low) use 0, Non Inverting (Active High) use 1
#define X_ENABLE_ON 1
#define Y_ENABLE_ON 1
#define Z_ENABLE_ON 1
// Disables axis when it's not being used.
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z false
#define DISABLE_E false
// Inverting axis direction
#define INVERT_X_DIR true
#define INVERT_Y_DIR true
#define INVERT_Z_DIR true
//// ENDSTOP SETTINGS:
// Sets direction of endstops when homing; 1=MAX, -1=MIN
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
// Delta robot radius endstop
//If true, axis won't move to coordinates less than zero.
#define min_software_endstop_z true
//If true, axis won't move to coordinates greater than the defined lengths below.
// If during homing the endstop is reached, ho many mm should the printer move back for the second try
#define ENDSTOP_X_BACK_MOVE 6
#define ENDSTOP_Y_BACK_MOVE 6
#define ENDSTOP_Z_BACK_MOVE 6
// For higher precision you can reduce the speed for the second test on the endstop
// during homing operation. The homing speed is divided by the value. 1 = same speed, 2 = half speed
#define ENDSTOP_X_RETEST_REDUCTION_FACTOR 6
#define ENDSTOP_Y_RETEST_REDUCTION_FACTOR 6
#define ENDSTOP_Z_RETEST_REDUCTION_FACTOR 6
// When you have several endstops in one circuit you need to disable it after homing by moving a
// small amount back. This is also the case with H-belt systems.
#define ENDSTOP_Z_BACK_ON_HOME 1
// You can disable endstop checking for print moves. This is needed, if you get sometimes
// false signals from your endstops. If your endstops don't give false signals, you
// can set it on for safety.
#define ALWAYS_CHECK_ENDSTOPS true
// maximum positions in mm - only fixed numbers!
// For delta robot Z_MAX_LENGTH is the maximum travel of the towers and should be set to the distance between the hotend
// and the platform when the printer is at its home position.
// If EEPROM is enabled these values will be overidden with the values in the EEPROM
#define X_MAX_LENGTH 175
#define Y_MAX_LENGTH 175
#define Z_MAX_LENGTH 200
// Coordinates for the minimum axis. Can also be negative if you want to have the bed start at 0 and the printer can go to the left side
// of the bed. Maximum coordinate is given by adding the above X_MAX_LENGTH values.
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 0
#define INVERT_Y_DIR 0
#define INVERT_Z_DIR 0
#define Z_HOME_DIR 1
#define X_MAX_LENGTH 200
#define Y_MAX_LENGTH 200
#define Z_MAX_LENGTH 170.8
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
// ## Movement settings ##
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_DIAGONAL_ROD 195 // mm
#define DELTA_ALPHA_A 210
#define DELTA_ALPHA_B 330
#define DELTA_ALPHA_C 90
#define DELTA_MAX_RADIUS 90
#define ROD_RADIUS 97.5
#define PRINTER_RADIUS 97.5
#define DELTA_HOME_ON_POWER 0
#define STEP_COUNTER
//#define SOFTWARE_LEVELING
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 200
#define MAX_FEEDRATE_Y 200
#define MAX_FEEDRATE_Z 2
#define HOMING_FEEDRATE_X 40
#define HOMING_FEEDRATE_Y 40
#define HOMING_FEEDRATE_Z 2
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 100
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 100
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define USE_ADVANCE 0
#define BAUDRATE 115200
#define POWER_INVERTING 0
#define KILL_METHOD 0
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 1
#undef PS_ON_PIN
#define JSON_OUTPUT 0
/* ======== Servos =======
Control the servos with
M340 P S / ServoID = 0..3 pulseInUs = 500..2500
#define FEATURE_SERVO 0
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define SERVO0_NEUTRAL_POS -1
#define SERVO1_NEUTRAL_POS -1
#define SERVO2_NEUTRAL_POS -1
#define SERVO3_NEUTRAL_POS -1
#define UI_SERVO_CONTROL 0
#define FEATURE_WATCHDOG 0
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 40
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 20
#define Z_PROBE_Y1 20
#define Z_PROBE_X2 160
#define Z_PROBE_Y2 20
#define Z_PROBE_X3 100
#define Z_PROBE_Y3 160
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#define SDSUPPORT 0
#undef SDCARDDETECT
#define SDCARDDETECT -1
#endif
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER 0
#define ADC_KEYPAD_PIN -1
#define LANGUAGE_EN_ACTIVE 1
#define LANGUAGE_DE_ACTIVE 1
#define LANGUAGE_NL_ACTIVE 0
#define LANGUAGE_PT_ACTIVE 1
#define LANGUAGE_IT_ACTIVE 1
#define LANGUAGE_ES_ACTIVE 1
#define LANGUAGE_FI_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 0
#define LANGUAGE_FR_ACTIVE 1
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 1
#define LANGUAGE_TR_ACTIVE 1
#define UI_PRINTER_NAME "BB120v1"
#define UI_PRINTER_COMPANY "BikinBot"
#define UI_ANIMATION 0
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 1
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 0
#define CASE_LIGHTS_PIN -1
#define UI_SET_PRESET_EXTRUDER_TEMP_PLA 190
#define UI_SET_PRESET_EXTRUDER_TEMP_ABS 240
#define UI_SET_MAX_EXTRUDER_TEMP 260
#define NUM_MOTOR_DRIVERS 0
#endif
"editMode": 2,
"processor": 0,
"baudrate": 115200,
"bluetoothSerial": -1,
"bluetoothBaudrate": 115200,
"xStepsPerMM": 80,
"yStepsPerMM": 80,
"zStepsPerMM": 80,
"xInvert": 0,
"xInvertEnable": 0,
"eepromMode": 1,
"yInvert": 0,
"yInvertEnable": 0,
"zInvert": 0,
"zInvertEnable": 0,
"extruder": [
"id": 0,
"heatManager": 3,
"pidDriveMin": 40,
"pidDriveMax": 230,
"pidMax": 255,
"sensorType": 1,
"sensorPin": "TEMP_0_PIN",
"heaterPin": "HEATER_0_PIN",
"maxFeedrate": 50,
"startFeedrate": 20,
"invert": "0",
"invertEnable": "0",
"acceleration": 5000,
"watchPeriod": 1,
"pidP": 7,
"pidI": 2,
"pidD": 40,
"advanceK": 0,
"advanceL": 0,
"waitRetractTemp": 150,
"waitRetractUnits": 0,
"waitRetract": 0,
"stepsPerMM": 370,
"coolerPin": -1,
"coolerSpeed": 255,
"selectCommands": "",
"deselectCommands": "",
"xOffset": 0,
"yOffset": 0,
"zOffset": 0,
"xOffsetSteps": 0,
"yOffsetSteps": 0,
"zOffsetSteps": 0,
"stepper": {
"name": "Extruder 0",
"step": "ORIG_E0_STEP_PIN",
"dir": "ORIG_E0_DIR_PIN",
"advanceBacklashSteps": 0,
"decoupleTestPeriod": 12,
"jamPin": -1,
"jamPullup": "0",
"mirror": "0",
"invert2": "0",
"stepper2": {
"uiLanguage": 0,
"uiController": 0,
"xMinEndstop": 4,
"yMinEndstop": 4,
"zMinEndstop": 4,
"xMaxEndstop": 4,
"yMaxEndstop": 4,
"zMaxEndstop": 4,
"motherboard": 33,
"driveSystem": 3,
"xMaxSpeed": 200,
"xHomingSpeed": 40,
"xTravelAcceleration": 100,
"xPrintAcceleration": 1000,
"yMaxSpeed": 200,
"yHomingSpeed": 40,
"yTravelAcceleration": 100,
"yPrintAcceleration": 1000,
"zMaxSpeed": 2,
"zHomingSpeed": 2,
"zTravelAcceleration": 100,
"zPrintAcceleration": 100,
"xMotor": {
"name": "X motor",
"step": "ORIG_X_STEP_PIN",
"dir": "ORIG_X_DIR_PIN",
"enable": "ORIG_X_ENABLE_PIN"
"yMotor": {
"name": "Y motor",
"step": "ORIG_Y_STEP_PIN",
"dir": "ORIG_Y_DIR_PIN",
"enable": "ORIG_Y_ENABLE_PIN"
"zMotor": {
"name": "Z motor",
"step": "ORIG_Z_STEP_PIN",
"dir": "ORIG_Z_DIR_PIN",
"enable": "ORIG_Z_ENABLE_PIN"
"enableBacklash": "0",
"backlashX": 0,
"backlashY": 0,
"backlashZ": 0,
"stepperInactiveTime": 360,
"maxInactiveTime": 0,
"xMinPos": 0,
"yMinPos": 0,
"zMinPos": 0,
"xLength": 200,
"yLength": 200,
"zLength": 170.8,
"alwaysCheckEndstops": "1",
"disableX": "0",
"disableY": "0",
"disableZ": "0",
"disableE": "0",
"xHomeDir": "-1",
"yHomeDir": "-1",
"zHomeDir": 1,
"xEndstopBack": 1,
"yEndstopBack": 1,
"zEndstopBack": 0,
"deltaDiagonalRod": 195,
"deltaHorizontalRadius": 97.5,
"deltaAlphaA": 210,
"deltaAlphaB": 330,
"deltaAlphaC": 90,
"deltaDiagonalCorrA": 0,
"deltaDiagonalCorrB": 0,
"deltaDiagonalCorrC": 0,
"deltaMaxRadius": 90,
"deltaRadiusCorrA": 0,
"deltaRadiusCorrB": 0,
"deltaRadiusCorrC": 0,
"deltaXOffsetSteps": 0,
"deltaYOffsetSteps": 0,
"deltaZOffsetSteps": 0,
"deltaSegmentsPerLine": 24,
"stepperHighDelay": 0,
"directionDelay": 0,
"allowQuadstepping": "1",
"doubleStepDelay": 0,
"maxJerk": 20,
"maxZJerk": 0.3,
"moveCacheSize": 16,
"moveCacheLow": 10,
"lowTicksPerMove": 250000,
"enablePowerOnStartup": "1",
"echoOnExecute": "1",
"sendWaits": "1",
"ackWithLineNumber": "1",
"killMethod": 0,
"useAdvance": "0",
"useQuadraticAdvance": "0",
"powerInverting": 0,
"mirrorX": 0,
"mirrorXMotor": {
"name": "Extruder 1",
"step": "ORIG_E1_STEP_PIN",
"dir": "ORIG_E1_DIR_PIN",
"mirrorY": 0,
"mirrorYMotor": {
"mirrorZ": "0",
"mirrorZMotor": {
"mirrorZ3": "0",
"mirrorZ3Motor": {
"name": "Extruder 2",
"step": "ORIG_E2_STEP_PIN",
"dir": "ORIG_E2_DIR_PIN",
"dittoPrinting": "0",
"featureServos": "0",
"servo0Pin": 11,
"servo1Pin": -1,
"servo2Pin": -1,
"servo3Pin": -1,
"featureWatchdog": "0",
"hasHeatedBed": "0",
"enableZProbing": "1",
"extrudeMaxLength": 160,
"featureController": 0,
"uiPrinterName": "RepRap",
"uiPrinterCompany": "Home made",
"uiPagesDuration": 4000,
"uiAnimation": "0",
"uiDisablePageswitch": "1",
"uiAutoReturnAfter": 30000,
"featureKeys": "0",
"uiEncoderSpeed": 1,
"uiReverseEncoder": "0",
"uiKeyBouncetime": 10,
"uiKeyFirstRepeat": 500,
"uiKeyReduceRepeat": 50,
"uiKeyMinRepeat": 50,
"featureBeeper": "0",
"uiPresetBedTempPLA": 60,
"uiPresetBedABS": 110,
"uiPresetExtruderPLA": 190,
"uiPresetExtruderABS": 240,
"uiMinHeatedBed": 30,
"uiMaxHeatedBed": 120,
"uiMinEtxruderTemp": 170,
"uiMaxExtruderTemp": 260,
"uiExtruderFeedrate": 2,
"maxBedTemperature": 120,
"bedSensorType": 1,
"bedSensorPin": "TEMP_1_PIN",
"bedHeatManager": 0,
"bedUpdateInterval": 5000,
"bedPidDriveMin": 80,
"bedPidDriveMax": 255,
"bedPidP": 196,
"bedPidI": 33,
"bedPidD": 290,
"bedPidMax": 255,
"bedDecoupleTestPeriod": 300,
"caseLightPin": -1,
"caseLightDefaultOn": "1",
"bedSkipIfWithin": 3,
"gen1T0": 25,
"gen1R0": 100000,
"gen1Beta": 4036,
"gen1MinTemp": -20,
"gen1MaxTemp": 300,
"gen1R1": 0,
"gen1R2": 4700,
"gen2T0": 25,
"gen2R0": 100000,
"gen2Beta": 4036,
"gen2MinTemp": -20,
"gen2MaxTemp": 300,
"gen2R1": 0,
"gen2R2": 4700,
"gen3T0": 25,
"gen3R0": 100000,
"gen3Beta": 4036,
"gen3MinTemp": -20,
"gen3MaxTemp": 300,
"gen3R1": 0,
"gen3R2": 4700,
"userTable0": {
"r1": 0,
"r2": 4700,
"temps": [],
"numEntries": 0
"userTable1": {
"r1": 0,
"r2": 4700,
"temps": [],
"numEntries": 0
"userTable2": {
"r1": 0,
"r2": 4700,
"temps": [],
"numEntries": 0
"tempHysteresis": 0,
"pidControlRange": 20,
"skipM109Within": 2,
"extruderFanCoolTemp": 50,
"minTemp": 150,
"maxTemp": 275,
"minDefectTemp": -10,
"maxDefectTemp": 290,
"arcSupport": "1",
"forceChecksum": "0",
"sdExtendedDir": "1",
"featureFanControl": "1",
"fanPin": "ORIG_FAN_PIN",
"featureFan2Control": "0",
"fan2Pin": "ORIG_FAN2_PIN",
"fanThermoPin": -1,
"fanThermoMinPWM": 128,
"fanThermoMaxPWM": 255,
"fanThermoMinTemp": 45,
"fanThermoMaxTemp": 60,
"fanThermoThermistorPin": -1,
"fanThermoThermistorType": 1,
"scalePidToMax": 0,
"zProbeBedDistance": 10,
"zProbePullup": "0",
"zProbeOnHigh": "0",
"zProbeXOffset": 0,
"zProbeYOffset": 0,
"zProbeWaitBeforeTest": "0",
"zProbeSpeed": 2,
"zProbeXYSpeed": 150,
"zProbeHeight": 40,
"zProbeStartScript": "",
"zProbeFinishedScript": "",
"featureAutolevel": "1",
"zProbeX1": 20,
"zProbeY1": 20,
"zProbeX2": 160,
"zProbeY2": 20,
"zProbeX3": 100,
"zProbeY3": 160,
"zProbeSwitchingDistance": 1,
"zProbeRepetitions": 1,
"sdSupport": "0",
"sdCardDetectPin": -1,
"sdCardDetectInverted": "0",
"uiStartScreenDelay": 1000,
"xEndstopBackMove": 5,
"yEndstopBackMove": 5,
"zEndstopBackMove": 2,
"xEndstopRetestFactor": 3,
"yEndstopRetestFactor": 3,
"zEndstopRetestFactor": 3,
"xMinPin": "ORIG_X_MIN_PIN",
"yMinPin": "ORIG_Y_MIN_PIN",
"zMinPin": "ORIG_Z_MIN_PIN",
"xMaxPin": "ORIG_X_MAX_PIN",
"yMaxPin": "ORIG_Y_MAX_PIN",
"zMaxPin": "ORIG_Z_MAX_PIN",
"deltaHomeOnPower": "0",
"fanBoardPin": -1,
"heaterPWMSpeed": 0,
"featureBabystepping": "1",
"babystepMultiplicator": 1,
"pdmForHeater": "0",
"pdmForCooler": "0",
"psOn": "ORIG_PS_ON_PIN",
"mixingExtruder": "0",
"featureAxisComp": "0",
"axisCompTanXY": 0,
"axisCompTanXZ": 0,
"axisCompTanYZ": 0,
"retractOnPause": 2,
"pauseStartCommands": "",
"pauseEndCommands": "",
"distortionCorrection": "0",
"distortionCorrectionR": 100,
"distortionPermanent": "1",
"distortionEndDegrade": 1,
"distortionXMin": 10,
"distortionXMax": 190,
"distortionYMin": 10,
"distortionYMax": 190,
"sdRunOnStop": "",
"featureRetraction": "1",
"autoretractEnabled": "0",
"retractionLength": 3,
"retractionLongLength": 13,
"retractionSpeed": 40,
"retractionZLift": 0,
"retractionUndoSpeed": 20,
"filamentChangeXPos": 0,
"filamentChangeYPos": 0,
"filamentChangeZAdd": 2,
"filamentChangeRehome": 1,
"fanKickstart": 200,
"servo0StartPos": -1,
"servo1StartPos": -1,
"servo2StartPos": -1,
"servo3StartPos": -1,
"uiDynamicEncoderSpeed": "1",
"uiServoControl": 0,
"killIfSensorDefect": "0",
"jamSteps": 220,
"jamSlowdownSteps": 320,
"jamSlowdownTo": 70,
"jamErrorSteps": 500,
"jamMinSteps": 10,
"jamAction": 1,
"primaryPort": 0,
"numMotorDrivers": 0,
"motorDrivers": [
"t": "None",
"s": "",
"invertDirection": "0",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1
"manualConfig": "",
"zHomeMinTemperature": 0,
"zHomeXPos": 999999,
"zHomeYPos": 999999,
"zHomeHeatHeight": 20,
"zHomeHeatAll": "1",
"zProbeZOffsetMode": 0,
"zProbeZOffset": 0,
"uiBedCoating": "1",
"langEN": "1",
"langDE": "1",
"langNL": "0",
"langPT": "1",
"langIT": "1",
"langES": "1",
"langFI": "0",
"langSE": "0",
"langFR": "1",
"langCZ": "0",
"langPL": "1",
"langTR": "1",
"accelerationFactorTop": 100,
"bendingCorrectionA": 0,
"bendingCorrectionB": 0,
"bendingCorrectionC": 0,
"supportLaser": "0",
"laserPin": -1,
"laserOnHigh": "1",
"defaultPrinterMode": 0,
"supportCNC": "0",
"cncWaitOnEnable": 300,
"cncWaitOnDisable": 0,
"cncEnablePin": -1,
"cncEnableWith": "1",
"cncDirectionPin": -1,
"cncDirectionCW": "1",
"startupGCode": "",
"jsonOutput": "0",
"bedLevelingMethod": 0,
"bedCorrectionMethod": 0,
"bedLevelingGridSize": 5,
"bedLevelingRepetitions": 5,
"bedMotor1X": 0,
"bedMotor1Y": 0,
"bedMotor2X": 200,
"bedMotor2Y": 0,
"bedMotor3X": 100,
"bedMotor3Y": 200,
"zProbeRequiresHeating": "0",
"zProbeMinTemperature": 150,
"adcKeypadPin": -1,
"sharedExtruderHeater": "0",
"extruderSwitchXYSpeed": 100,
"dualXAxis": "0",
"boardFanSpeed": 255,
"hasMAX6675": false,
"hasMAX31855": false,
"hasGeneric1": false,
"hasGeneric2": false,
"hasGeneric3": false,
"hasUser0": false,
"hasUser1": false,
"hasUser2": false,
"numExtruder": 1,
"version": 92.9,
"primaryPortName": ""
I'm using:
- Arduino mega2560
as you expect.
#include "pins.h"
#define MAXTEMP 275
on this endstop.
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
// Delta settings
#define MAX_JERK 20
#undef PS_ON_PIN
#define SDSUPPORT 0
#undef SDCARDDETECT
#endif
#endif
"editMode": 2,
"processor": 0,
"baudrate": 115200,
"xStepsPerMM": 80,
"yStepsPerMM": 80,
"zStepsPerMM": 80,
"xInvert": 0,
"xInvertEnable": 0,
"eepromMode": 1,
"yInvert": 0,
"yInvertEnable": 0,
"zInvert": 0,
"zInvertEnable": 0,
"extruder": [
"id": 0,
"heatManager": 3,
"pidDriveMin": 40,
"pidDriveMax": 230,
"pidMax": 255,
"sensorType": 1,
"maxFeedrate": 50,
"invert": "0",
"watchPeriod": 1,
"pidP": 7,
"pidI": 2,
"pidD": 40,
"advanceK": 0,
"advanceL": 0,
"waitRetract": 0,
"stepsPerMM": 370,
"coolerPin": -1,
"coolerSpeed": 255,
"xOffset": 0,
"yOffset": 0,
"zOffset": 0,
"xOffsetSteps": 0,
"yOffsetSteps": 0,
"zOffsetSteps": 0,
"stepper": {
"jamPin": -1,
"jamPullup": "0",
"mirror": "0",
"invert2": "0",
"stepper2": {
"uiLanguage": 0,
"uiController": 0,
"xMinEndstop": 4,
"yMinEndstop": 4,
"zMinEndstop": 4,
"xMaxEndstop": 4,
"yMaxEndstop": 4,
"zMaxEndstop": 4,
"motherboard": 33,
"driveSystem": 3,
"xMaxSpeed": 200,
"xHomingSpeed": 40,
"yMaxSpeed": 200,
"yHomingSpeed": 40,
"zMaxSpeed": 2,
"zHomingSpeed": 2,
"xMotor": {
"name": "X motor",
"yMotor": {
"name": "Y motor",
"zMotor": {
"name": "Z motor",
"backlashX": 0,
"backlashY": 0,
"backlashZ": 0,
"xMinPos": 0,
"yMinPos": 0,
"zMinPos": 0,
"xLength": 200,
"yLength": 200,
"zLength": 170.8,
"disableX": "0",
"disableY": "0",
"disableZ": "0",
"disableE": "0",
"xHomeDir": "-1",
"yHomeDir": "-1",
"zHomeDir": 1,
"xEndstopBack": 1,
"yEndstopBack": 1,
"zEndstopBack": 0,
"deltaAlphaA": 210,
"deltaAlphaB": 330,
"deltaAlphaC": 90,
"maxJerk": 20,
"maxZJerk": 0.3,
"moveCacheLow": 10,
"sendWaits": "1",
"killMethod": 0,
"useAdvance": "0",
"mirrorX": 0,
"mirrorXMotor": {
"mirrorY": 0,
"mirrorYMotor": {
"mirrorZ": "0",
"mirrorZMotor": {
"mirrorZ3": "0",
"mirrorZ3Motor": {
"servo0Pin": 11,
"servo1Pin": -1,
"servo2Pin": -1,
"servo3Pin": -1,
"uiAnimation": "0",
"featureKeys": "0",
"bedSensorType": 1,
"bedPidP": 196,
"bedPidI": 33,
"bedPidD": 290,
"bedPidMax": 255,
"caseLightPin": -1,
"gen1T0": 25,
"gen1R0": 100000,
"gen1Beta": 4036,
"gen1MinTemp": -20,
"gen1MaxTemp": 300,
"gen1R1": 0,
"gen1R2": 4700,
"gen2T0": 25,
"gen2R0": 100000,
"gen2Beta": 4036,
"gen2MinTemp": -20,
"gen2MaxTemp": 300,
"gen2R1": 0,
"gen2R2": 4700,
"gen3T0": 25,
"gen3R0": 100000,
"gen3Beta": 4036,
"gen3MinTemp": -20,
"gen3MaxTemp": 300,
"gen3R1": 0,
"gen3R2": 4700,
"userTable0": {
"r1": 0,
"r2": 4700,
"temps": [],
"numEntries": 0
"userTable1": {
"r1": 0,
"r2": 4700,
"temps": [],
"numEntries": 0
"userTable2": {
"r1": 0,
"r2": 4700,
"temps": [],
"numEntries": 0
"minTemp": 150,
"maxTemp": 275,
"arcSupport": "1",
"fanThermoPin": -1,
"scalePidToMax": 0,
"zProbeXOffset": 0,
"zProbeYOffset": 0,
"zProbeSpeed": 2,
"zProbeHeight": 40,
"zProbeX1": 20,
"zProbeY1": 20,
"zProbeX2": 160,
"zProbeY2": 20,
"zProbeX3": 100,
"zProbeY3": 160,
"sdSupport": "0",
"fanBoardPin": -1,
"axisCompTanXY": 0,
"axisCompTanXZ": 0,
"axisCompTanYZ": 0,
"sdRunOnStop": "",
"jamSteps": 220,
"jamMinSteps": 10,
"jamAction": 1,
"primaryPort": 0,
"motorDrivers": [
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1
"manualConfig": "",
"zProbeZOffset": 0,
"langEN": "1",
"langDE": "1",
"langNL": "0",
"langPT": "1",
"langIT": "1",
"langES": "1",
"langFI": "0",
"langSE": "0",
"langFR": "1",
"langCZ": "0",
"langPL": "1",
"langTR": "1",
"laserPin": -1,
"laserOnHigh": "1",
"supportCNC": "0",
"cncEnablePin": -1,
"startupGCode": "",
"jsonOutput": "0",
"bedMotor1X": 0,
"bedMotor1Y": 0,
"bedMotor2X": 200,
"bedMotor2Y": 0,
"bedMotor3X": 100,
"bedMotor3Y": 200,
"adcKeypadPin": -1,
"dualXAxis": "0",
"hasUser0": false,
"hasUser1": false,
"hasUser2": false,
"numExtruder": 1,
"version": 92.9,
You have configured the normal filament cooling fan that gets controlled by M106/M107. These commands get added by slicers.
If you expected a fan for the extruder it self to be turned on when heating, you should have assigned it to the extruder cooler fan:
Which as you see you did not. Make sure if you do to remove the normal fan feature or it will not work since both use same output.
