Z probe problem Tronxy X3
Hello,
I have upgraded my Tronxy X3 with an inductive sensor. Currently I'm running repetier 0.92.9.
My sensor is mounted 40mm left to the nozzle. Open and close state are sensed correctly with G31 command. So the sensor works correctly.
FEATURE_Z_PROBE is enabled. When I now home X and Y and then home Z the printhead doesn't move in X and Y direction. So the probe is not over the bed and of course can't detect it and the nozzle runs into the Bed.
What parameters do I have to adjust?
Here is the part of my configuration:
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1 // war 0
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 1
#define Z_PROBE_X_OFFSET -40
#define Z_PROBE_Y_OFFSET 5
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 100
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 0
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 0
#define Z_PROBE_Y1 -50
#define Z_PROBE_X2 -50
#define Z_PROBE_Y2 50
#define Z_PROBE_X3 50
#define Z_PROBE_Y3 50
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
Currently I have a Mali board which didn't support that. So is it possible with only the Z probe?
But how do I initialize now my printer? What commands do I have to send before printing?
Does MIN_HARDWARE_ENDSTOP_Z to be true or false?
I have MIN_HARDWARE_ENDSTOP_Z on false. When I do a G28 it moves around 15mm up, then homes X and Y, then the head moves to ZHOME_X_POS =141 and ZHOME_Y_POS =100 but does nothing in Z!?. Then it moves to X0 Y0 Z0 where Z0 is the position where I started the homing. Is that correct?
After the G28 I move Z to 5mm and then I run G32 S2. In the log I can see that it stores the bed values. But when I move to the four bed corners at a height of 0,2mm the distance between bed and nozzle is not constant. I thought that after a G32 there should be the same distance all over the bed? It differs at around 0,15mm. So What went wrong?
Here my new settings:
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 0
#define INVERT_Y_DIR 0
#define INVERT_Z_DIR 1
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define X_MAX_LENGTH 225
#define Y_MAX_LENGTH 230
#define Z_MAX_LENGTH 318
#define X_MIN_POS -21
#define Y_MIN_POS -40
#define Z_MIN_POS 0
#define Z2_MINMAX_PIN -1
#define HOMING_FEEDRATE_X 70
#define HOMING_FEEDRATE_Y 70
#define HOMING_FEEDRATE_Z 6
#define HOMING_ORDER HOME_ORDER_ZXYTZ
#define ZHOME_PRE_RAISE 2
#define ZHOME_PRE_RAISE_DISTANCE 5
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 141
#define ZHOME_Y_POS 100
#define ENABLE_BACKLASH_COMPENSATION 1
#define EXTRUDER_IS_Z_PROBE 0
#define Z_PROBE_Y_OFFSET -5
#define Z_PROBE_SPEED 3
#define Z_PROBE_SWITCHING_DISTANCE 2
#define Z_PROBE_REPETITIONS 2
#define Z_PROBE_HEIGHT 1.00
#define Z_PROBE_X1 20
#define Z_PROBE_Y1 20
#define Z_PROBE_X2 180
#define Z_PROBE_Y2 20
#define Z_PROBE_X3 100
#define Z_PROBE_Y3 180
But the way it should work, what I expect, should be this procedure:
Sending G28:
Move Z up an view mm, then home X and Y then move the sensor to the center of the bed, then Z probe.
So the start code could be only G28; G32.
Is that possible or do I get something wrong?
