Z-homing no endstop hit
after installing the Repetier firmware 0.9.2 to my RUMBA board I had the following problem:
X and Y homing work fine, as expected. In Z - homing the printhead only moves a short distance (about 5 mm) towards the optical endstop, but does not hit it, if the start distance had been more.
I experimented with all possible combinations of endstop setups, but no success.
Falling back to Marlin Firmware there are no problems.
So there should not be cross talk effects.
Nevertheless i would prefer the Repetier firmware, because it supports the new CYCLOPS (dual extruder with 1 nozzle/heater) from E3D. Marlin does not support this feature yet.
Could anyone give a hint?
schumsel293
schumsel293
