z homing, Heater Decoupled
First:
I'm not using a z limit switch so i want to disable z homing how to do that?
second:
my heat bed was working properly but suddenly it stopped heating but sensor is doing well as it showing home temp
I started printing and enabled it after a while it starts heating but after a while printing stopped due to heater decouple
the i can't heat it manually but I found out if i touched the two component in the pic i can control it manually but also after a while during printing it shows to me heater decoupled
Third:
when heater decoupled how to continue the object printing after reset by lcd or emergency stop?
thx
http://imgur.com/a/3sdio
second:
Third:
thx
imgur.com/a/3sdio
i defined that but it's not working
about decoupling
It was working properly and the problem not just about decoupling
I can't control it manually without making the two component in ramps connected just identified in the image
previously it was working without any problems
i can't control it before the 1 component touch the 2 component in this pic of ramps
http://imgur.com/a/kbVfW
and it won't even work during making the object unless i make the touch each other
and z after i deleted its limit switch from the firmware it's making homing every time before printing
This is the link of picture
I lost control of heated bed
If I want to control it I should the two parts illustrated in picture touch each other and I think that would harm than ramps board
If there was no direct contact between them the heated bed won't start hearing manually or during printing
referring Picture you connected heatbed to Extruder heater Pins.
you also did not connect power for heatbed.
refer this:
http://docs.my-home-fab.de/images/my-home-fab/artikel/hardware/electronics/reprap-ramps/ramps-1.4-schema-1920px.jpg
but suddenly it stopped working
thermistor is doing well
heat bed is doing well
but the problem is in the heat bed control
during printing it would work by itself without any problem but it shuts down again after a while
and i can't control it before printing of during printing
I can't control my heat bed before or during printing
During printing the heat bed switch on and off randomly
And can't switch it on before printing
ND the pic in this link
