Weird problem of communication with printer !!
I'm currently installing and doing setup of Repetier Server on a Raspberry. I installed the image offered on Repetier Server and have setup it correctly I guess (created users, connected to Wifi, setup camera).
I have setup in it my printer (Prusa i3) but I have a problem. The printer is this one (https://www.3dprintersonlinestore.com/full-acrylic-reprap-prusa-i3-kit) and from specs it looks it has Repetier firmware in it so should work easily with Repetier server. Repetier Server detects well the printer, I have setup the connection to the USB FTDI device and setup at 115200.
When I click in Extruder tabs or Printer design tab (not sure of name in english as I use Repetier Server in French), none of the controls work No way to move the printer in either axis, or control bed heating or extruder heating !
I don't know what I'm missing here as I have read all docs I found on Repetier Server website and on Internet and find nothing wrong ! Any ideas ?
Thanks for help,
Vincèn
