LCD Display DGOM 128x64 Repetier 0.92
i have a problem with installing RepRap DOGM128 Grafik-Featurecontroller into Repetier 0.92 + ramps 1.4 + Mega 2560.
I bought it here:
_ttps://www.electronic-things.de/shop/RepRap-Shop/Elektronik/RAMPS-und-ARDUINO/DOGM128-Grafik-Featurecontroller-154.html
I found manual, but it works only for Repetier 0.91 (i found places where to change). But for Repetier 0.92 i couldn't find. May be it's because of U8GLIB (0.91) vs U8GLIB_ex (0.92).
I put manual at attachment.
Does somebody have any ideas, what i should change? I would appreciate any help.:)
Thank you.
I couldn't solve this problem. I've changed in config tool, but there is two options:
-"Smartcontroller from RepRap discount on a RAMPS or RUMBA board"
-"RepRapDiscount Full Graphic Smart Controller 128*64"
Whisch one did you mean?
2) I couldn't find a right place in ui.h, if i choose one of these controllers. Could you check please and give me a link ? Because i should change all pin numbers.
3) in manual for this controller is written, that i should use "#define U8GLIB_ST7565", but in new firmware only
#define U8GLIB_ST7920. is it ok?
Thank you.
thank you. i will try.
