Cannot get my inductive probe to work with Repetier FW.. please help!
So I have been trying to switch from Marlin to Repetier but I cannot get my inductive probe to work. After lots of hours of experimenting with z-probe height the nozzle is always way too high when starting a print.
I have set the probe height to such a value that after G28 Z0 a sheet of paper barely fits under the nozzle. However, after performing G32 the nozzle is too high. No matter what I do, if I start a print the nozzle is always too high.
In Marlin I just have #define Z_PROBE_OFFSET_FROM_EXTRUDER -0.55 and automatic bed leveling works perfectly. What do I do wron in Repetier?
The inductive Z probe is connected instead of a Z microswitch. Please help me...
Here is my Config:
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
#define NUM_EXTRUDER 1
#define MOTHERBOARD 33
#include "pins.h"
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define BOARD_FAN_SPEED 255
#define FAN_THERMO_PIN -1
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL -1
#define BLUETOOTH_BAUD 115200
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 0
#define XAXIS_STEPS_PER_MM 80
#define YAXIS_STEPS_PER_MM 80
#define ZAXIS_STEPS_PER_MM 1600
#define EXTRUDER_FAN_COOL_TEMP 0
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define RETRACT_ON_PAUSE 3
#define PAUSE_END_COMMANDS ""
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 812.08
#define EXT0_INVERSE 1
#define EXT0_ENABLE_ON 0
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 50
#define EXT0_HEAT_MANAGER 3
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_WAIT_RETRACT_TEMP 180
#define EXT0_WAIT_RETRACT_UNITS 2
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 2
#define HAVE_HEATED_BED 1
#define HEATED_BED_MAX_TEMP 150
#define SKIP_M190_IF_WITHIN 3
#define HEATED_BED_HEATER_PIN 9
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 275
// ## Laser configuration ##
automatically disabled.
#define SUPPORT_LASER 0
#define LASER_PIN -1
#define LASER_ON_HIGH 1
// ## CNC configuration ##
#define SUPPORT_CNC 0
#define CNC_WAIT_ON_DISABLE 0
#define CNC_ENABLE_PIN -1
#define CNC_ENABLE_WITH 1
#define CNC_DIRECTION_PIN -1
#define CNC_DIRECTION_CW 1
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define ENDSTOP_X_BACK_ON_HOME 0
#define ENDSTOP_Y_BACK_ON_HOME 0
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 1
#define INVERT_Y_DIR 0
#define INVERT_Z_DIR 1
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define X_MAX_LENGTH 245
#define Y_MAX_LENGTH 299
#define Z_MAX_LENGTH 200
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
// ## Movement settings ##
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 200
#define MAX_FEEDRATE_Y 200
#define MAX_FEEDRATE_Z 2
#define HOMING_FEEDRATE_X 60
#define HOMING_FEEDRATE_Y 60
#define HOMING_FEEDRATE_Z 2
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_JERK 10
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define USE_ADVANCE 0
#define BAUDRATE 250000
#define POWER_INVERTING 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 1
#undef PS_ON_PIN
#define JSON_OUTPUT 0
/* ======== Servos =======
Control the servos with
#define FEATURE_SERVO 0
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define SERVO0_NEUTRAL_POS -1
#define SERVO1_NEUTRAL_POS -1
#define SERVO2_NEUTRAL_POS -1
#define SERVO3_NEUTRAL_POS -1
#define UI_SERVO_CONTROL 0
#define FEATURE_WATCHDOG 0
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define Z_PROBE_BED_DISTANCE 3
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 17
#define Z_PROBE_Y_OFFSET -47
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_REPETITIONS 2
#define Z_PROBE_HEIGHT 1
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 17
#define Z_PROBE_Y1 250
#define Z_PROBE_X2 210
#define Z_PROBE_Y2 250
#define Z_PROBE_X3 17
#define Z_PROBE_Y3 10
#define BED_LEVELING_METHOD 1
#define BED_LEVELING_GRID_SIZE 3
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 1
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#define SDSUPPORT 0
#undef SDCARDDETECT
#define SDCARDDETECT -1
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER 11
#define ADC_KEYPAD_PIN -1
#define LANGUAGE_EN_ACTIVE 1
#define LANGUAGE_DE_ACTIVE 0
#define LANGUAGE_NL_ACTIVE 0
#define LANGUAGE_PT_ACTIVE 0
#define LANGUAGE_IT_ACTIVE 0
#define LANGUAGE_ES_ACTIVE 0
#define LANGUAGE_FI_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 0
#define LANGUAGE_FR_ACTIVE 0
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 0
#define LANGUAGE_TR_ACTIVE 0
#define UI_ANIMATION 0
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 1
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 0
#define CASE_LIGHTS_PIN -1
#define UI_SET_PRESET_EXTRUDER_TEMP_PLA 190
#define UI_SET_PRESET_EXTRUDER_TEMP_ABS 240
#define UI_SET_MAX_HEATED_BED_TEMP 150
#define UI_SET_MAX_EXTRUDER_TEMP 275
#define NUM_MOTOR_DRIVERS 0
