skipping steps? rounding error?
I have a Zonestar printer with repetier firmware in it, version 0.92.9 and it looks like its skipping some g-codes if the move they make is under 1mm or something.
the bottom infill turns into a bunch of V's instead of neat parallel lines. and a circle turns into a kind of pyramid-like shape with steps.
its very repeatable and remains the same if i rotate the part 90 degrees. my g-code file prints fine on a friends printer and a file that works for him gives the same errors on mine.
Anyone got some clues what this could be?
Thanks a lot, remco
