BL Touch congif help needed
what commands do I use to set the Z height from the bed. the instruction from the manufactures page has G-code but they come back as unknown commands, M851, M280 P0 S10 are examples. I know the distance between my nozzle and the lowest plastic part of the BL Touch is 8.2mm.
I also have the XY and Z all blinking question marks on the LCD display. the BLTouch self tests at start up. not really sure where to go from here.
Cartiesion printer
Ramps 1.4 mega
BL Touch is connected at the Z-MIN and D11
using the newest developer Repetier firmware config
#define UI_BED_COATING 0
#define FEATURE_Z_PROBE 1
#define EXTRUDER_IS_Z_PROBE 0
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 1
#define Z_PROBE_X_OFFSET -30
#define Z_PROBE_Y_OFFSET 16
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 0.1
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 25
#define Z_PROBE_Y1 25
#define Z_PROBE_X2 155
#define Z_PROBE_Y2 90
#define Z_PROBE_X3 95
#define Z_PROBE_Y3 155
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#define Z_PROBE_BED_DISTANCE 10 how far to raise Z between probing points
