Random Disconnects on New Install
I've been running repetier server for some time now on a pi3 with no issues. I ran into an issue where new gcodes weren't being processed until repetier server was restarted. As there was no fix for that, I got a new microsd card and copied the pi img to it and started using the new install. I've noticed at random my wanhao Di3 that's connected to the PI will reset, of course, causing the print to stop with it.
The logs out of repetier server don't show any errors or anything out of the ordinary. IE error M999 or something. The only thing I can find is the below in dmesg:
[224441.716301] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
[224441.716385] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
[224441.812590] usb 1-1.5: USB disconnect, device number 18
[224441.812923] ftdi_sio ttyUSB0: error from flowcontrol urb
Has anyone else experienced this and any suggestions on where to look for more info. As an aside, nothing changed in my Wanhao's config.
Here's my setup
rPi3
Wanhao Di3 running repetier FW .91 (not sure what rev)
RepRap m Prime running repetier FW dev (not printing at the moment, but still connected. hotend issues)
USB webcam
Full DMESG @ ;http://pastebin.com/YkjiBw1q
Full print log out of repetier from a print that ran for a bit before a restart occured: https://paste.ee/p/OOZYj
Thank you!
