Not in host directly. In Slic3r if run with plater enabled you can load a stl that defines a new region and assign different parameter to that region and slice. Then load gcode into host to print.
Hello to all!! Please help )) I did not get the right shape of result( the top side is moved to one side with about 15mm and continued to print... the result is like this one
Could be endstop crosstalk - try with always check endstops disabled. Or one jerk was to hard loosing steps or motor current too low or it simply got cought by a part warping up.
