no network integration possible
Good morning,
I'm new to Raspberry and also new to Repetier-Server. I loaded the latest image of the Repetier server from here and connected the Pi to my network. Pi didn't connect and didn't get an IP from my network. Connection is only possible to the integrated SSID and than with the 10.10.10.1 IP. After getting to the config page I'm able to click to my wifi. But when clicking to my SSID system doesn't ask for the encryption key and I lost connection to RP-server. My Network allows new clients and mac filter is switched of. I've seen that there have been such errors in the past but still the same issue with the latest version. Any ideas?
Klaus
Klaus
Ping also doesn't respond. I'll investigate more today.
:-q
In the time between I installed Ocoprint to see the difference between both systems. I would like to have the setup options with the octopi-network.txt file in Repetier-Server.
I pasted 2 screenshots into my post but also can see them only in edit mode.
happy again
