Anet A8, cannot install Firmware
i have a Anet A8 Printer and i would like to install the Repetier-Firmware because i plan to update the Printer with AutoLeveling.
I use the ARDUINO 1.8.1, my Mainboard ist this when i upload the Firmware i become this Massage:
Arduino: 1.8.1 (Linux), Board: "Arduino/Genuino Uno"
sketch/fastio.h:17:30: note: in definition of macro 'MASK'
#define MASK(PIN) (1 << PIN)
sketch/fastio.h:48:25: note: in expansion of macro '_WRITE'
#define WRITE(IO, v) _WRITE(IO, v)
sketch/Printer.h:1004:9: note: in expansion of macro 'WRITE'
WRITE(Y_STEP_PIN,!START_STEP_WITH_HIGH);
exit status 1
'DIO31_DDR' was not declared in this scope
What do i make wrong??
Thank You
exit status 1
Thank You
goto tools/board and select the correct board.
i don´t know which one is compatible to the anet but ithink it might be arduino/genuino mega
With the arduino/genuino mega the Message is:
Arduino: 1.8.1 (Linux), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Globale Variablen verwenden 4114 Bytes (50%) des dynamischen Speichers, 4078 Bytes für lokale Variablen verbleiben. Das Maximum sind 8192 Bytes.
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
Beim Hochladen des Sketches ist ein Fehler aufgetreten
with the Sangunio (i found that tip here)
Arduino: 1.8.1 (Linux), Board: "Sanguino, ATmega1284 or ATmega1284P (16 MHz)"
Globale Variablen verwenden 4114 Bytes (25%) des dynamischen Speichers, 12270 Bytes für lokale Variablen verbleiben. Das Maximum sind 16384 Bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x73
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x74
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x74
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x0a
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x49
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x6e
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x66
The connection to the Printer should be OK, the Terminal show me this information:
start
Info:External Reset
Info: 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000
Free RAM:12337
SD init fail
wait
wait
wait
wait
lsusb show me:
Bus 002 Device 002: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
dmesg show me:
[ 5338.496315] usb 2-1: New USB device found, idVendor=1a86, idProduct=7523
[ 5338.496323] usb 2-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 5338.496327] usb 2-1: Product: USB2.0-Serial
[ 5339.042080] usbcore: registered new interface driver usbserial
[ 5339.042468] usbcore: registered new interface driver usbserial_generic
[ 5339.042601] usbserial: USB Serial support registered for generic
[ 5339.044077] usbcore: registered new interface driver ch341
[ 5339.044095] usbserial: USB Serial support registered for ch341-uart
[ 5339.044114] ch341 2-1:1.0: ch341-uart converter detected
[ 5339.056351] usb 2-1: ch341-uart converter now attached to ttyUSB0
at the board are 3 microchips, the big one in the middle of the Board is:
ATME GA1284P
AU 1636
and two near the USB Connector:
CH340G
202686677
and:
74HC4050D
CKW14101
TnD1619B
Thank you
as far as i know it´s not supported "out of the box" by arduino ide and there are a couple of arduino
"add-ons" out in the net so i ´m sorry i cannot help.
so may be the guys from here can help :
http://anet3d-forum.de/
not 1284
