debuglevel:14
after I run a print I get    DebugLevel:14 from my heat bed and then both heaters shut off,How do I stop this ????
tazo1jd@gmail.com
  • Fix the reason that causes firmware to go into dry run mode. In log sou see that a heater is defect or decoupled due to not getting hot fast enough. So assuming they work like normal you need to increase the decouple time for that device.
    Also make sure it is not the host just sending M111 S14 also that only happens if you change debug mode.
  • what do you mean By   HOST ?  were can I find that?          Also make sure it is not the host just sending M111 S14 also that only happens if you change debug mode   ?????
  • I mean make sure you have no M114 S14 added somewhere in your scripts and do not hit dry run button in manual controls.
