Laser turned on on all moves.
Hi all,
Hope someone can help me. I'm doing some testing in laser mode but i don't get it. After selecting laser mode and during g0/g1/g28 moves the laser pin is always going high. Tested it on D44 and D4 both with the same result. Did also try a test script with the same result. Running version 1.0.0dev. Also in printer mode the pin stays low during moves.
g28
m452
g0 z400
g0 z300
m3 s0
g0 z400
g0 z300
g0 z400
g0 z300
m3 s255
g0 z400
g0 z300
g28
Some results on manual commands:
21:42:09.810 : N152 M452*38
21:42:09.810 : PrinterMode:Laser
21:43:20.052 : N153 M3 S0*100
21:43:20.052 : LaserOn:0
21:43:35.747 : N154 M3 S255*97
21:43:35.747 : LaserOn:255
Thank you,
Arjan
(if laser on/off is swapped change from #define LASER_ON_HIGH 1 to #define LASER_ON_HIGH 0 in configuration.h)
try as follows:
M452
G28
M3
G1 X100 F200
G0 X0
M5
from configuration.h :
use existing FDM slicers to laser the output. Laser width is extrusion width.
automatically disabled.
i have laser working without any problem. refer text from configuration.h
which controller do you use (f.e. ramps or something else)
check pinlist for double use etc.
software(dev version) is for shure not the problem as i use it .
along with Repetier-Firmware. If not, see .
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
This file is optimized for version 1.0.0dev
as you expect.
#define NUM_EXTRUDER 2
#define MOTHERBOARD 33
#include "pins.h"
#undef FAN_PIN
#define FAN_PIN 9
#undef FAN2_PIN
#define FAN2_PIN 10
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define BOARD_FAN_SPEED 255
#define BOARD_FAN_MIN_SPEED 0
#define FAN_THERMO_PIN -1
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL -1
#define BLUETOOTH_BAUD 115200
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 3
#define XAXIS_STEPS_PER_MM 40.06
#define YAXIS_STEPS_PER_MM 40.1
#define ZAXIS_STEPS_PER_MM 40.05
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 50
#define EXT0_TEMPSENSOR_TYPE 97
#define EXT0_HEATER_PIN 42
#define EXT0_INVERSE 0
#define EXT0_ENABLE_ON 0
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 50
#define EXT0_HEAT_MANAGER 3
#define EXT0_PREHEAT_TEMP 190
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define EXT1_X_OFFSET 0
#define EXT1_Y_OFFSET 0
#define EXT1_Z_OFFSET 0
#define EXT1_STEPS_PER_MM 50
#define EXT1_TEMPSENSOR_TYPE 1
#define EXT1_HEATER_PIN 8
#define EXT1_INVERSE 0
#define EXT1_ENABLE_ON 0
#define EXT1_MIRROR_STEPPER 0
#define EXT1_INVERSE2 0
#define EXT1_MAX_FEEDRATE 50
#define EXT1_HEAT_MANAGER 3
#define EXT1_PREHEAT_TEMP 190
#define EXT1_WATCHPERIOD 1
#define EXT1_PID_I 2
#define EXT1_PID_D 40
#define EXT1_PID_MAX 255
#define EXT1_ADVANCE_K 0
#define EXT1_ADVANCE_L 0
#define EXT1_JAM_PIN -1
#define EXT1_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define JAM_METHOD 1
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define USE_GENERIC_THERMISTORTABLE_1
#define GENERIC_THERM1_T0 25
#define GENERIC_THERM1_R0 100000
#define GENERIC_THERM1_BETA 4036
#define GENERIC_THERM1_MIN_TEMP -20
#define GENERIC_THERM1_MAX_TEMP 300
#define GENERIC_THERM1_R1 0
#define GENERIC_THERM1_R2 4700
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 0
#define HAVE_HEATED_BED 1
#define SKIP_M190_IF_WITHIN 3
#define HEATED_BED_HEATER_PIN 57
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 275
// ## Laser configuration ##
#define SUPPORT_LASER 1
#define LASER_PIN 4
#define LASER_WARMUP_TIME 0
// ## CNC configuration ##
#define SUPPORT_CNC 0
#define CNC_WAIT_ON_DISABLE 0
#define CNC_ENABLE_PIN -1
#define CNC_ENABLE_WITH 1
#define CNC_DIRECTION_PIN -1
#define CNC_DIRECTION_CW 1
#define ENDSTOP_PULLUP_X_MAX false
#define ENDSTOP_PULLUP_Y_MAX false
#define ENDSTOP_PULLUP_Z_MAX false
#define min_software_endstop_z true
#define DOOR_PIN -1
#define DOOR_PULLUP 1
#define DOOR_INVERTING 1
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 5
#define ENDSTOP_X_BACK_ON_HOME 0
#define ENDSTOP_Y_BACK_ON_HOME 0
#define MOVE_X_WHEN_HOMED 0
#define MOVE_Y_WHEN_HOMED 0
#define MOVE_Z_WHEN_HOMED 0
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 1
#define INVERT_Y_DIR 0
#define INVERT_Z_DIR 1
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR 1
#define X_MAX_LENGTH 408
#define Y_MAX_LENGTH 408
#define Z_MAX_LENGTH 408
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define Z2_MINMAX_PIN -1
#define DISTORTION_PERMANENT 0
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
// ## Movement settings ##
#define DELTA_SEGMENTS_PER_SECOND_PRINT 99 // Move accurate setting for print moves
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_DIAGONAL_ROD 332.05 // mm
#define DELTA_ALPHA_A 209.99
#define DELTA_ALPHA_B 330.05
#define DELTA_ALPHA_C 90
#define END_EFFECTOR_HORIZONTAL_OFFSET 34.1
#define CARRIAGE_HORIZONTAL_OFFSET 31.2
#define DELTA_MAX_RADIUS 135
#define ROD_RADIUS 183.47
#define PRINTER_RADIUS 248.77
#define DELTA_HOME_ON_POWER 0
#define STEP_COUNTER
#define DELTA_X_ENDSTOP_OFFSET_STEPS 12
#define DELTA_Y_ENDSTOP_OFFSET_STEPS 6
//#define SOFTWARE_LEVELING
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 500
#define MAX_FEEDRATE_Y 500
#define MAX_FEEDRATE_Z 500
#define HOMING_FEEDRATE_X 100
#define HOMING_FEEDRATE_Y 100
#define HOMING_FEEDRATE_Z 100
#define ZHOME_PRE_RAISE 0
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 60
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 60
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 60
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 60
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 60
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 60
#define MAX_JERK 50
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define Z4_STEP_PIN ORIG_E3_STEP_PIN
#define Z4_DIR_PIN ORIG_E3_DIR_PIN
#define USE_ADVANCE 0
#define BAUDRATE 115200
#define POWER_INVERTING 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 2
#undef PS_ON_PIN
#define JSON_OUTPUT 0
/* ======== Servos =======
Control the servos with
M340 P S / ServoID = 0..3 pulseInUs = 500..2500
#define FEATURE_SERVO 0
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define SERVO0_NEUTRAL_POS -1
#define SERVO1_NEUTRAL_POS -1
#define SERVO2_NEUTRAL_POS -1
#define SERVO3_NEUTRAL_POS -1
#define UI_SERVO_CONTROL 0
#define FEATURE_WATCHDOG 0
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 0
#define FEATURE_Z_PROBE 1
#define EXTRUDER_IS_Z_PROBE 0
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 1
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 5
#define Z_PROBE_XY_SPEED 1000
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 10
#define FEATURE_AUTOLEVEL 0
#define Z_PROBE_X1 -110
#define Z_PROBE_Y1 -60
#define Z_PROBE_X2 110
#define Z_PROBE_Y2 -60
#define Z_PROBE_X3 0
#define Z_PROBE_Y3 130
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#define SDSUPPORT 0
#undef SDCARDDETECT
#define SDCARDDETECT -1
#endif
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_FAN2_CONTROL 1
#define FEATURE_CONTROLLER 11
#define ADC_KEYPAD_PIN -1
#define LANGUAGE_EN_ACTIVE 1
#define LANGUAGE_DE_ACTIVE 0
#define LANGUAGE_NL_ACTIVE 0
#define LANGUAGE_PT_ACTIVE 0
#define LANGUAGE_IT_ACTIVE 0
#define LANGUAGE_ES_ACTIVE 0
#define LANGUAGE_FI_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 0
#define LANGUAGE_FR_ACTIVE 0
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 0
#define LANGUAGE_TR_ACTIVE 0
#define UI_PRINTER_NAME "Freez"
#define UI_PAGES_DURATION 2000
#define UI_SPEEDDEPENDENT_POSITIONING 1
#define UI_AUTORETURN_TO_MENU_AFTER 120000
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 2
#define UI_REVERSE_ENCODER 1
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 0
#define CASE_LIGHTS_PIN 58
#define UI_SET_MAX_EXTRUDER_TEMP 260
#define NUM_MOTOR_DRIVERS 0
#endif
(even i don´t have the controller but that shouldn´t matter)
i just connected a led with series resistor to d4 for simulating laser
as expected , it works. are you shure your mega is ok?
only thing i see problematic is the memory warning in compiler and for me it looks like not running reliable depending on memory.
But as i´m not familiar with deltas i have no idea what and how to optimize
But it's also strange that the pin is going high only during movement and only during laser mode.
thats exactly what it shall do.....!!!
if it stops and laser would be on you would just make things burning.
it´s wanted that laser is on only during moves
when i set drive system to 0 everything is ok.but not useable for you
may be you start a bug report for delta system for this case.
btw, if you set m3 s0 before go move and m3 s255 before g1 move it should work, but thats not the way it should
so found the time for short crosstest.
switched my due testsetup over to drive system 3 and that works like a charm...
g0 switches off , g1 on m5 also switches off correct.
so if not memory related there might be a bug in avr-version, i´m not shure
i checked the code which is identical for due and avr and as it works perfect on my due also in delta mode i think it´s
memory problem on the avr.
but maybe you start bug report as the not correct working behavior is reproducable
