Nozzle Distance wrong between Homing and Printing
Hello all together,
i have a little problem an di hope anyone can help me. I have an Anet A8 with the Repetier Firmware 0.92.9. I leveld the Nozzle/Bed only with the screws under the bed. The nozzle is perfectly leveld. When i click Homing, the nozzle also has a perfect distance to the bed. But when i start a print, the nozzle has a distance to the bed, i think 0,3mm. You can see it in the Video. But i don´t know what is the problem. Can anybody help me?
Here is my Start G-Code from Cura Slicer and my Repetier Config
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G1 Z15.0 F9000 ;move the platform down 15mm
G92 E0 ;zero the extruded length
G1 F200 E3 ;extrude 3mm of feed stock
G92 E0 ;zero the extruded length again
G1 F9000
Good morning,
I have this same exact problem. After I run Manual leveling and start a print, the nozzle is too high for the filament to stick to the bed. This happened after I flashed over to 92.10. Why is this happening? I try to correct this by moving my bed closer (knobs) as I'm printing and when I try Manual leveling again, the nozzle is too close to the bed.
If I type G28, G1 x100 y100 z0 and then m84 and level the bed, it will print too high also.
I might just go back to starting a print, turning the machine off and moving the nozzle around as I level. Too bad. It really seemed like a great option.
I will try the "babysteps". I can pause my print and adjust it that way if needed.
Sorry for the long delay in responding. Z Length of 198 was the magic number. Everything has fallen into place and I'm very happy.
Thanks Support!
