Laser turned on on all moves.
edited February 2017 in Questions & Answers
Hi all,
Hope someone can help me. I'm doing some testing in laser mode but i don't get it. After selecting laser mode and during g0/g1/g28 moves the laser pin is always going high. Tested it on D44 and D4 both with the same result. Did also try a test script with the same result. Running version 1.0.0dev. Also in printer mode the pin stays low during moves.
g28
m452
g0 z400
g0 z300
m3 s0
g0 z400
g0 z300
g0 z400
g0 z300
m3 s255
g0 z400
g0 z300
g28
Some results on manual commands:
21:42:09.810 : N152 M452*38
21:42:09.810 : PrinterMode:Laser
21:43:20.052 : N153 M3 S0*100
21:43:20.052 : LaserOn:0
21:43:35.747 : N154 M3 S255*97
21:43:35.747 : LaserOn:255
Thank you,
Arjan
  • edited February 2017
    why do you move Z in laser operation? (Laser gets not activated in z-move and also not in g28 and G0 moves)
    (if laser on/off is swapped change  from #define LASER_ON_HIGH 1 to #define LASER_ON_HIGH 0 in configuration.h)
    try as follows:
    M452
    G28
    M3
    G1 X100 F200
    G0 X0
    M5
    from configuration.h :
    use existing FDM slicers to laser the output. Laser width is extrusion width.
    automatically disabled.
  • Turning on laser mode and doing z moves is not strange in my opinion. I have a delta printer and i can image that you change the height to burn the next layer (change the focus point).
    Also in my case m3 s0 or m3 s255 and m5 gives all the same result for all moves! Laser is turned on.
    Also laser is turned on during the whole time in this script no change at all!:
    m452
    g28
    g0 z400
    m3 s0
    g1 x100 f1000
    m3 s255
    g1 x-100
    m5
    g1 x100
    m3 s255
    g1 x-100
    m3 s0
    g0 x100 f1000
    m3 s255
    g0 x-100
    m5
    g0 x100
    m3 s255
    g0 x-100
    g28
  • so as nothing changes at all... seems your wiring is the problem.
    i have laser working  without any problem. refer text from configuration.h
  • Wiring? I just measure the state of my D4 pin. So it must be a software thing.
    some more informations of your setup would be useful.....
    which controller do you use (f.e. ramps or something else)
    check pinlist for double use etc.
    software(dev version) is for shure not the problem as i use it .
  • No problem, i use a ramps board 1.4. Good to know that you are using the same version. Tonight i would also try the light pin because that one is working for the light and re-assign the light to another pin in the config. Also i have chosen D4 because of the PWM support.
    This is my current configuration.h:
    along with Repetier-Firmware. If not, see .
    #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
    This file is optimized for version 1.0.0dev
    as you expect.
    #define NUM_EXTRUDER 2
    #define MOTHERBOARD 33
    #include "pins.h"
    #undef FAN_PIN
    #define FAN_PIN 9
    #undef FAN2_PIN
    #define FAN2_PIN 10
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define BOARD_FAN_MIN_SPEED 0
    #define FAN_THERMO_PIN -1
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL -1
    #define BLUETOOTH_BAUD 115200
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 3
    #define XAXIS_STEPS_PER_MM 40.06
    #define YAXIS_STEPS_PER_MM 40.1
    #define ZAXIS_STEPS_PER_MM 40.05
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 50
    #define EXT0_TEMPSENSOR_TYPE 97
    #define EXT0_HEATER_PIN 42
    #define EXT0_INVERSE 0
    #define EXT0_ENABLE_ON 0
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_HEAT_MANAGER 3
    #define EXT0_PREHEAT_TEMP 190
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_I 2
    #define EXT0_PID_D 40
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define EXT1_X_OFFSET 0
    #define EXT1_Y_OFFSET 0
    #define EXT1_Z_OFFSET 0
    #define EXT1_STEPS_PER_MM 50
    #define EXT1_TEMPSENSOR_TYPE 1
    #define EXT1_HEATER_PIN 8
    #define EXT1_INVERSE 0
    #define EXT1_ENABLE_ON 0
    #define EXT1_MIRROR_STEPPER 0
    #define EXT1_INVERSE2 0
    #define EXT1_MAX_FEEDRATE 50
    #define EXT1_HEAT_MANAGER 3
    #define EXT1_PREHEAT_TEMP 190
    #define EXT1_WATCHPERIOD 1
    #define EXT1_PID_I 2
    #define EXT1_PID_D 40
    #define EXT1_PID_MAX 255
    #define EXT1_ADVANCE_K 0
    #define EXT1_ADVANCE_L 0
    #define EXT1_JAM_PIN -1
    #define EXT1_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define JAM_METHOD 1
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define USE_GENERIC_THERMISTORTABLE_1
    #define GENERIC_THERM1_T0 25
    #define GENERIC_THERM1_R0 100000
    #define GENERIC_THERM1_BETA 4036
    #define GENERIC_THERM1_MIN_TEMP -20
    #define GENERIC_THERM1_MAX_TEMP 300
    #define GENERIC_THERM1_R1 0
    #define GENERIC_THERM1_R2 4700
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_HEATER_PIN 57
    #define MIN_EXTRUDER_TEMP 150
    #define MAXTEMP 275
    // ## Laser configuration ##
    #define SUPPORT_LASER 1
    #define LASER_PIN 4
    #define LASER_WARMUP_TIME 0
    // ## CNC configuration ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define ENDSTOP_PULLUP_X_MAX false
    #define ENDSTOP_PULLUP_Y_MAX false
    #define ENDSTOP_PULLUP_Z_MAX false
    #define min_software_endstop_z true
    #define DOOR_PIN -1
    #define DOOR_PULLUP 1
    #define DOOR_INVERTING 1
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 5
    #define ENDSTOP_X_BACK_ON_HOME 0
    #define ENDSTOP_Y_BACK_ON_HOME 0
    #define MOVE_X_WHEN_HOMED 0
    #define MOVE_Y_WHEN_HOMED 0
    #define MOVE_Z_WHEN_HOMED 0
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_X_DIR 1
    #define INVERT_Y_DIR 0
    #define INVERT_Z_DIR 1
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR 1
    #define X_MAX_LENGTH 408
    #define Y_MAX_LENGTH 408
    #define Z_MAX_LENGTH 408
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define Z2_MINMAX_PIN -1
    #define DISTORTION_PERMANENT 0
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 190
    #define DISTORTION_YMAX 190
    // ## Movement settings ##
    #define DELTA_SEGMENTS_PER_SECOND_PRINT 99 // Move accurate setting for print moves
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_DIAGONAL_ROD 332.05 // mm
    #define DELTA_ALPHA_A 209.99
    #define DELTA_ALPHA_B 330.05
    #define DELTA_ALPHA_C 90
    #define END_EFFECTOR_HORIZONTAL_OFFSET 34.1
    #define CARRIAGE_HORIZONTAL_OFFSET 31.2
    #define DELTA_MAX_RADIUS 135
    #define ROD_RADIUS 183.47
    #define PRINTER_RADIUS 248.77
    #define DELTA_HOME_ON_POWER 0
    #define STEP_COUNTER
    #define DELTA_X_ENDSTOP_OFFSET_STEPS 12
    #define DELTA_Y_ENDSTOP_OFFSET_STEPS 6
    //#define SOFTWARE_LEVELING
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 500
    #define MAX_FEEDRATE_Y 500
    #define MAX_FEEDRATE_Z 500
    #define HOMING_FEEDRATE_X 100
    #define HOMING_FEEDRATE_Y 100
    #define HOMING_FEEDRATE_Z 100
    #define ZHOME_PRE_RAISE 0
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 60
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 60
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 60
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 60
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 60
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 60
    #define MAX_JERK 50
    #define MAX_ZJERK 0.3
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define Z4_STEP_PIN ORIG_E3_STEP_PIN
    #define Z4_DIR_PIN ORIG_E3_DIR_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 115200
    #define POWER_INVERTING 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 2
    #undef PS_ON_PIN
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P S / ServoID = 0..3 pulseInUs = 500..2500
    #define FEATURE_SERVO 0
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define SERVO0_NEUTRAL_POS -1
    #define SERVO1_NEUTRAL_POS -1
    #define SERVO2_NEUTRAL_POS -1
    #define SERVO3_NEUTRAL_POS -1
    #define UI_SERVO_CONTROL 0
    #define FEATURE_WATCHDOG 0
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 0
    #define FEATURE_Z_PROBE 1
    #define EXTRUDER_IS_Z_PROBE 0
    #define Z_PROBE_PULLUP 0
    #define Z_PROBE_ON_HIGH 1
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_Y_OFFSET 0
    #define Z_PROBE_SPEED 5
    #define Z_PROBE_XY_SPEED 1000
    #define Z_PROBE_REPETITIONS 1
    #define Z_PROBE_HEIGHT 10
    #define FEATURE_AUTOLEVEL 0
    #define Z_PROBE_X1 -110
    #define Z_PROBE_Y1 -60
    #define Z_PROBE_X2 110
    #define Z_PROBE_Y2 -60
    #define Z_PROBE_X3 0
    #define Z_PROBE_Y3 130
    #define BED_LEVELING_METHOD 0
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 0
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #endif
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_FAN2_CONTROL 1
    #define FEATURE_CONTROLLER 11
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 0
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 0
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 0
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 0
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 0
    #define LANGUAGE_TR_ACTIVE 0
    #define UI_PRINTER_NAME "Freez"
    #define UI_PAGES_DURATION 2000
    #define UI_SPEEDDEPENDENT_POSITIONING 1
    #define UI_AUTORETURN_TO_MENU_AFTER 120000
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 2
    #define UI_REVERSE_ENCODER 1
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 0
    #define CASE_LIGHTS_PIN 58
    #define UI_SET_MAX_EXTRUDER_TEMP 260
    #define NUM_MOTOR_DRIVERS 0
    #endif
  • ok, as i work with Due i can´t check directly, but ihave a ramps board free so i´ll try to set it up tomorrow to check your setup.
    (even i don´t have the controller but that shouldn´t matter)
    so i´ve set it up , just downloaded fresh dev. version and copied your configuration.h in it.
    i just connected a led with series resistor to d4  for simulating laser
    as expected , it works. are you shure your mega is ok?
    only thing i see problematic is the memory warning in compiler and for me it looks like not running reliable depending on memory.
    But as i´m not familiar with deltas i have no idea what and how to optimize
    Thanks for your effort. I have the same memory warning for more then one year.  But I 3d printed a lot of stuff without problems. So i expect that is not my problem. My mega could be wrong, but on the other hand my dual extruder works, heated bed, lights,  end stops, lcd... and i tried d4 and d44. But i will also tryout some other pins just to make sure. But it's also strange that the pin is going high only during movement and only during laser mode. And in all other situations just low. I will do some more testing.
    Ty.
    thats exactly what it shall do.....!!!
    if it stops and laser would be on you would just make things burning.
    it´s wanted that laser is on only during moves
  • but also during the g0 moves
    And in my case i cannot do a move without laser turned on. A possible workaround would probably be switch from printer mode  to laser mode all the time :-)
    i rechecked and also saw that now ,also no reaction on m5. but in this case i cannot help so gcode is same for all drive systems.
    when i set drive system to 0 everything is ok.but not useable for you
    may be you start a bug report for delta system for this case.
    btw, if you set m3 s0 before go move and m3 s255 before g1 move it should work, but thats not the way it should
    so found the time for short crosstest.
    switched my due testsetup over to drive system 3 and that works like a charm...
    g0 switches off , g1 on  m5 also switches off correct.
    so if not memory related there might be a bug in avr-version, i´m not shure
  • In my script above i tried everything. m3 s0 and also m3 s255  both in combinations with g0 and g1 all with the same result.
  • seems to be memory problem.
    i checked the code which is identical for due and avr and as it works perfect on my due also in delta mode i think it´s
    memory problem on the avr.
    but maybe you start bug report as the not correct working behavior is reproducable
  • Will try to analyse the source code first. Maybe i can find a clue there.
  • already merged avr version vs due version. no difference
    This seems a bit unlogical:
       #if defined(SUPPORT_LASER) && SUPPORT_LASER
       else if(Printer::mode == PRINTER_MODE_LASER)
       p->secondSpeed = ((p->delta[X_AXIS] != 0 || p->delta[Y_AXIS] != 0) && (LaserDriver::laserOn || p->delta[E_AXIS] != 0) ? LaserDriver::intensity : 0);
       p->delta[E_AXIS] = 0;
       #endif
    In combination with this:
            case 452:
    waitUntilEndOfAllMoves();
                Printer::mode = PRINTER_MODE_LASER;
  • What is here unlogical?
    the else if statement. Now c is not my native programming language, so i could be mistaken ofcourse. :-)
    Looking longer at this code i think this is not the problem. Sometimes a bit hard to read c code. I thought that the else if was a part of the if statement but it is not. Still no solution :-(
    Luckily weekend is coming up :-)
  • #if is a preprocessor if and decides which code parts get compiled at all. The following else is part of c++ logic. SO watch out for # signs indicating non c++ but preprocessor statements.
  • Thank you for the answer, i understand now why. Just to make the final code shorter.
  • I really don't get it. Switched the pin number of the laser and the case light to see what happens. This is also very pleasant because now i can see easy when the laser is on (case light). But the problem is the same, during all moves it stays on.
    What happens with this code:
    g28
    m452
    m3 s0
    g0 z300
    m3 s255
    g0 z400
    The light turns on, homing starts and flickers during the multiple end stops hits, moves to z300 and z400 with lights on and then the lights go off.
    Added also comment output to all changeIntensity calls. And almost during all moves the repetier.h calls the changeIntensity(255). I think i'm going to use the fan pin. Because this is not working at all for me. My added comment in the repetier.h file:
                Com::printFLN(PSTR("Added for testing, change intensity to 255 (2)"));
                LaserDriver::changeIntensity(255);
  • I don't understand it. G0 has laser off so it should not be on. So you are using wrong pins or pins are used for other functions as well so they get enabled. Something like that.
  • Still strange that RAYwB was able to reproduce the not functioning m5 command. Running my delta on ramps 1.4.
  • Haven't seen that comment. I see M5 sets laserOn to false and adding moves uses this condition:
    so essentially setting intensity 0 if laser is off. And G0/Z moves also have always laser disabled. And from your description nothing of this is happening in your case.
  • Thanks to a hint from RAyWB I found something. Just fixed dev version. For deltas laser was always set to 255 and not secondSpeed which is what we set in M3/M5. Should now work much better I think (please test if possible).
    I was just starting to migrate my firmware to the m106 setup. But i will give it another go, will keep you updated.
    Working now as designed! Thanks for your effort! So no wrong pins etc ;-) the problem was exactly in the code i pasted above only i was mistaking the file it was in (was a bit hard to see what file was open due to the many tabs).
    But after all this testing i'm wondering why would i not go for a fan pin so i have pwm and the ability for greyscale? Less code in memory. Are there any drawbacks?
    Regards and thanks again!
    Arjan
  • Fan does not change between G0/G1 and is always on while G1 will enable laser and disable at end for safety etc. So the laser solution is the one you want. It is easy to mod it a bit in driver.cpp where you set intensity. There you can also call analogWrite(pin,intensity) if it is a hardware pwm or set the fan speed there. Fans get a 16Hz signal so it is more like a dotted line maybe, depending how much frequency the driver needs to set power. I somehow assume you need a high frequency to do grayscale.
