Heatbed
i have a repetier/kossel utwith a heatbed.
I use 2 PU of 12v 7AMP one for the arduino and one for the heatbed, the hetbed is 100W silicone. i use the on/off setting and I am using the 0.92v from last friday
I can setup de temperature for exemple 60deg C and the heatbed gets there but when it starts to print if the tempereture drops, it can not revover to the temperature, this will cause a def error and the cut of all power on the heatbed and extruder.
Can somebody help me on this, i can not understand why this is happening.
thank you in advance
You were 100% right :-)
I switched the PU and this stoped, probably one of them shuts down and couses the DEC that turns all power down for safety.
Will will buy a better PU soon, this is my first kossel, i am learning and i expect to build a second one were all problems spoted with the first are corrected.
Thank you agin for your support
