2 IP adress one PI3
dont know if ist normal, but never see this before, i just install server on my PI3 with your image for PI3, and i acces to adress 192.168.2.119, and this is the adress where i see the PI3 on my network, BUT i got access too a the IP 192.168.2.112 ....same port 3344
my network dont have any device a this adress....
wich side the trouble...PI3 or Server, or my network....do to have a clue, thanks
  • If you connect pi with ethernet and wifi each device gets it's own ip address. It even has a local connection127.0.0.1 like all network computers as well. So this is possible. You can even have several ip addresses on one network device also this is not configured by default.
