Reprap Discount Smart Controller LCD Issue
When I upload my code to RAMPS 1.4 with Reprap Discount Smart Controller, the screen powers on but gives bars in second and fourth rows and blank in first and third. I will attach photo. When I upload Marlin, the display works fine. Any suggestions?
FROM UIFCONFIG
#define UI_DISPLAY_CHARSET 2
/** Select type of beeper
0 = none
1 = Piezo connected to pin
2 = Piezo connected to a pin over I2C
#ifndef BEEPER_TYPE
#define BEEPER_TYPE 0
#define BEEPER_TYPE_INVERTING false
#if BEEPER_TYPE==1 && !defined(BEEPER_PIN)
#define BEEPER_PIN 37
#if BEEPER_TYPE==2
#define BEEPER_ADDRESS 0x40 // I2C address of the chip with the beeper pin
#define BEEPER_PIN _BV(7)  // Bit value for pin 8
#define COMPILE_I2C_DRIVER  // We need the I2C driver as we are using i2c
What display type do you use?
0 = No display - do not use here. Set FEATURE_CONTROLLER 0 instead
1 = LCD Display with 4 bit data bus
2 = LCD Display with 8 bit data bus (currently not implemented, fallback to 1)
3 = LCD Display with I2C connection, 4 bit mode
4 = Use the slower LiquiedCrystal library bundled with arduino.
    IMPORTANT: You need to uncomment the LiquidCrystal include in Repetier.pde for it to work.
               If you have Sanguino and want to use the library, you need to have Arduino 023 or older. (13.04.2012)
5 = U8G supported display
#define UI_DISPLAY_TYPE 5
#if UI_DISPLAY_TYPE == DISPLAY_U8G // Special case for graphic displays
// You need to define which controller you use and set pins accodringly
// For software spi assign these definitions
// SCK Pin:  UI_DISPLAY_D4_PIN
// Mosi Pin: UI_DISPLAY_ENABLE_PIN
// CD Pin:   UI_DISPLAY_RS_PIN
// ST7920 with software SPI
#define U8GLIB_ST7920
// SSD1306 with software SPI
//#define U8GLIB_SSD1306_SW_SPI
// SH1106 with software SPI
// U8GLIB_SH1106_SW_SPI
// SSD1306 over I2C using hardware I2C pins
//#define U8GLIB_SSD1306_I2C
// For the 8 bit ks0108 display you need to set these pins
// UI_DISPLAY_D0_PIN,UI_DISPLAY_D1_PIN,UI_DISPLAY_D2_PIN,UI_DISPLAY_D3_PIN,UI_DISPLAY_D4_PIN,UI_DISPLAY_D5_PIN,UI_DISPLAY_D6_PIN,UI_DISPLAY_D7_PIN
// UI_DISPLAY_ENABLE_PIN,UI_DISPLAY_CS1,UI_DISPLAY_CS2,
// UI_DISPLAY_DI,UI_DISPLAY_RW_PIN,UI_DISPLAY_RESET_PIN
//#define U8GLIB_KS0108
//#define U8GLIB_KS0108_FAST
// UI_DISPLAY_RS_PIN = CS
// UI_DISPLAY_D5_PIN = A0
//#define U8GLIB_ST7565_NHD_C2832_HW_SPI
#define UI_LCD_WIDTH 128
#define UI_LCD_HEIGHT 64
//select font size
#define UI_FONT_6X10 //default font
#ifdef UI_FONT_6X10
#define UI_FONT_WIDTH 6
#define UI_FONT_HEIGHT 10
#define UI_FONT_SMALL_HEIGHT 7
#define UI_FONT_DEFAULT repetier_6x10
#define UI_FONT_SMALL repetier_5x7
#define UI_FONT_SMALL_WIDTH 5 //smaller font for status display
#define UI_ANIMATION false  // Animations are too slow
//calculate rows and cols available with current font
#define UI_COLS (UI_LCD_WIDTH/UI_FONT_WIDTH)
#define UI_ROWS (UI_LCD_HEIGHT/UI_FONT_HEIGHT)
#define UI_DISPLAY_CHARSET 3
/** Number of columns per row
Typical values are 16 and 20
#define UI_COLS 20
Rows of your display. 2 or 4
#define UI_ROWS 4
#endif // UI_DISPLAY_TYPE
/* What type of chip is used for I2C communication
0 : PCF8574 or PCF8574A or compatible chips.
1 : MCP23017
#define UI_DISPLAY_I2C_CHIPTYPE 0
// 0x40 till 0x4e for PCF8574, 0x40 for the adafruid RGB shield, 0x40 - 0x4e for MCP23017
// Official addresses have a value half as high!
#define UI_DISPLAY_I2C_ADDRESS 0x4e
// For MCP 23017 define which pins should be output
#define UI_DISPLAY_I2C_OUTPUT_PINS 65504
// Set the output mask that is or'd over the output data. This is needed to activate
// a backlight switched over the I2C.
// The adafruit RGB shields enables a light if the bit is not set. Bits 6-8 are used for backlight.
#define UI_DISPLAY_I2C_OUTPUT_START_MASK 0
// For MCP which inputs are with pullup. 31 = pins 0-4 for adafruid rgb shield buttons
#define UI_DISPLAY_I2C_PULLUP 31
/* How fast should the I2C clock go. The PCF8574 work only with the lowest setting 100000.
A MCP23017 can run also with 400000 Hz */
#define UI_I2C_CLOCKSPEED 100000L
Define the pin
#if UI_DISPLAY_TYPE == DISPLAY_I2C // I2C Pin configuration
#define UI_DISPLAY_RS_PIN _BV(4)
#define UI_DISPLAY_RW_PIN _BV(5)
#define UI_DISPLAY_ENABLE_PIN _BV(6)
#define UI_DISPLAY_D0_PIN _BV(0)
#define UI_DISPLAY_D1_PIN _BV(1)
#define UI_DISPLAY_D2_PIN _BV(2)
#define UI_DISPLAY_D3_PIN _BV(3)
#define UI_DISPLAY_D4_PIN _BV(0)
#define UI_DISPLAY_D5_PIN _BV(1)
#define UI_DISPLAY_D6_PIN _BV(2)
#define UI_DISPLAY_D7_PIN _BV(3)
FROM CONFIG
#define FEATURE_CONTROLLER 11
Image can be seen if you right click and select copy link address and search
