Toggle navigation
Categories
Discussions
About Us
Privacy Policy
Sign In
Home
Repetier-Firmware
General
Z AXIS TRAVEL DISTANCE IS DIFFERENT BETWEEN SOFTWARE AND ACTUAL WORLD
daniro
January 2017
in
General
Z AXIS PHYSICAL LIMIT IS 250 mm, when i input a value of 25 to Z IT GOES TO THE UPPER LIMIT. (IT SAYS IT'S mm UNITS BUT... SEEMS TO BE IN cm?
MY PRINTER IS GEETECH PRUSA ALUMINUM I3 , FIRMWARE REPTIER MARYLIN
THANKS FOR YOUR HELP
MartinH
January 2017
seems like you have the z steps/mm set wrong in your firmware
What type Z rods are fitted? M5 threaded rods, M8 threaded rods or M8 4 start lead screws ?
daniro
January 2017
M8 THREADED RODS, DEFUALT STEPS ARE 2560 STEPS/mm
MartinH
January 2017
And what controller board ?
daniro
January 2017
solved, changed the steps of z to 426.67.
daniro
January 2017
control board SANUINOLOLU 4A4998
MartinH
January 2017
426 is more a 4 start lead screw size
make sure you have the 3 jumpers installed under each 4998 driver pcb to set 1/16 microsteping.
Sign In
or
Register
to comment.
