Well when you buy a thermistor they should tell you what you buy.
Decoupled means heater and thermistor are not responding as expected. See log for mor einformation why you get it. It might be at beginning when it does not heat up also you are powering 100% and later when you have reached target temperature it might be temperature leaving allowed corridor.
Seems like you have set a thermistor for extruder 2 that is not connected to that extruder. Maybe the bed thermsitor. So firmware sees no temp. raise because the thermistor is not getting hot since it is not the one on extruder.
