G32 inconsistent with G33
Hi everyone,
I know there are loads of threads about autoleveling issues. But I haven't seen my particular issue yet.
Printer: Anet A8 (Zonestar type)
Modifications: inductive probe. No Z endstops.
Procedure:
- Power on
- Home X+Y
- G32
- G33
Symptoms:
After a G32, I would expect that the average bed height + rotation is calibrated. So doing G33 after G32 should result in a bump map that is close to 0 (I know my bed's warp is <0.5mm). However, the bump map generated from G33 has a bias - almost -2mm on each measured point. How can this be? It seems to me the G32 probed measurements are not consistent with G33's measurements.
Second thing which I found strange: once G33 is done, as expected, Z is moving with X and Y. But when I re-home X, it moves the Z axis down a lot. This would be OK seeing as the bump map does have a big offset. But it does it every time I home X. In other words, if I keep homing X, Z will eventually crash into the bed.
Is this a consequence of not having a Z max endstop?
Thanks a lot for the help!
