OpenGL/Graphics card not detected
Hello,
I upgraded to the latest driver (version 376.33) for my NVIDIA GeForce GTX 860M graphics card but after doing so Repetier Host cannot detect OpenGL and/or graphics card properly. I tried re-installing the driver to no avail. The output window shows the following at start up:
11:50:11.531 : OpenGL version:1.1.0
11:50:11.531 : OpenGL extensions:GL_WIN_swap_hint GL_EXT_bgra GL_EXT_paletted_texture
11:50:11.531 : OpenGL renderer:GDI Generic
11:50:11.531 : Fast VBOs for rendering not supported. Using slower default method.
If I remember correctly, before upgrading the driver it used to print the name of my graphics card and OpenGL 4.5 etc. I have tried to use other OpenGL applications since upgrading the driver and they work fine.
I am using Repetier Host 1.0.6 (have not had any reason to upgrade because it has been stable), could upgrading to the latest version help? I rather not upgrade at this time unless it is sure to fix this problem of course.
If I start Repetier Host with my integrated graphics (Intel HD4600) Repetier Host prints the following:
12:04:21.660 : OpenGL version:4.3.0 - Build 20.19.15.4531
12:04:21.660 : OpenGL extensions:GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_blend_color GL_EXT_abgr (...a long list...)
12:04:21.679 : OpenGL renderer:Intel(R) HD Graphics 4600
12:04:21.679 : Using fast VBOs for rendering is possible
So here the detection works but unfortunately the 3d related stuff is very slow with the integrated graphics.
Any ideas how to fix?
It's a new i6 kaby lake 7600k with Nvidia GTX 1070 Windows 10 pro and after installing new nvidia driver the Repetier Host can't recognise the Open Gl.
I remember that with the older nvidia drivers I had no problems at all.
