Z Probe not working with G30
Hi, Sorry for starting a new discussion, but I have not seen a solution to my issue. I have been struggling with this for over a week and would really appreciate some help.
I have a home built CNC machine with a print head attached. Electronic for 3d printing is:
arduino-mega2560 with Ramps 1.4. XYZ steppers powered by Gecko drivers hooked up to step and dir on Ramps board, printhead by Polu driver on Ramps board.
I have successfully printed items. I want to enable auto levelling as I want to quickly change from CNC to 3d Printer mode.
Z axis protection on Z Max pin. Z probe switch connected to Z Min pin, switch normally open.
Testing using G31 works. Using G30 to test fails, I have to do an emergency stop as Z axis continues to drive down even when switch is activated.
Log below:
Homed all axis:
N19 G28 X0 *67
X:0.00 Y:0.00 Z:0.000 E:0.0000
N22 G28 Y0 *74
N24 G28 Z0 *79
X:0.00 Y:0.00 Z:59.600 E:0.0000
Tested G31
N34 G31 *12
Z-probe state:L
Activated switch:
N37 G31 *15
Z-probe state:H
config.h Z auto portion:
#define FEATURE_Z_PROBE 1
#define Z_PROBE_BED_DISTANCE 20
#define Z_PROBE_PULLUP 1
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 15
#define Z_PROBE_SWITCHING_DISTANCE 10
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 6.25
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 0
#define Z_PROBE_Y1 45
#define Z_PROBE_X2 0
#define Z_PROBE_Y2 235
#define Z_PROBE_X3 279
#define Z_PROBE_Y3 100
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
Update:
Using Repetier host v1.06 on Windows 7, firmware 0.92
Hi Lars
Thank you very much for responding and your advice. Problem was that I was too nervous and expecting the G30 to be triggered by me manually when it was much higher up.
I now have the machine auto levelling. Still need to dial it in to set Z0, but that should not be too hard.
New config.h
#define Z_PROBE_XY_SPEED 100
#define Z_PROBE_HEIGHT 7.65
#define Z_PROBE_START_SCRIPT "G28 Z G28 X G28 Y"
