Hangs near the begining, perhaps G92 slow?
Debuging Host to my Firmware communication using Repetier Host is not going well.
I have checked the data in the Rx buffer, and all commands have been tested. These work with
the terminal program probably since its slow manual entry. I have a 64byte RxBuffer and
can preload it before outputting "start" . That also worked fine. However the Host
in ping pong modes times out when the instruction replies with status information
in the following format Reply_Value ok on a single line.
In non ping pong mode this seems to
be accepted and there are no timeout. I wish I had a typical bootup listing to see if
I have a problem with output formatting. The following boot and start sequence is
what I receive in the Repetier debug window;
start
N1 M140 S0*100
N2 M84*29
ok
ok
N1 M110*34 Restarted due to start
N2 M115*36
N4 M114*35 //WHERE IS N3, I never see it.
N5 M111 S6*98
ok (for N1)
N6 T0*60
FHamori Version 6.1 12/6/2016
X0.0 Y0.0 Z0.0 E0.0 ok ( for N2 )
ok (for N3)
N7 M80*28
ok (for N4)
ok (for N5)
N8 M107*45
N9 G28*26
ok (for N6)
ok (for N7)
N10 G1 Z5 F5000*53 //Problem because Z moves very slowly??
ok (for N8)
N11 G21*42
ok (for N9)
N12 G90*35
ok (for N10)
N13 G92 E0*117
ok (for N11)
N14 G1 Z0.35 F7800*22 (This did run?)
ok (for N12)
I dont know if this is correctly understood by me.
I tried modifying the acknowledge to be on a separate line, but nothing really changed.
Also an "rs10" with no space separation never does any resend and I also "tryed rs 10"
which also doesn't respond. Should it be "rs N10"
